Stepper motors vibrating
PaulKruger
[SOLVED]: Stepper motors vibrating
Post by PaulKruger » Mon Jun 23, 2014 3:03 pm
Found the problem. As with most, it can be attributed to not paying attention. ( not pointing fingers of course, but no one else was around )
[[ Remember the saying, "We found the enemy and it is us" ]]
I made a mod as I built using parallel connectors and cables and an old printer A/B switch box for the Arduino. In the process I managed to skip a pin when soldering and was off by one, leaving one servo wire unconnected. It appears that also had a negative effect on the other axis because when I resolved that wiring error both problems went away.
I was then able to run the script to have the machine use a ball point pen to write SHAPEOKO 2 ! :D
Now on to learn to do something sorta-useful.
In case anyone is interested in seeing how I did my wiring visit my page for photos. This allows me to move the Arduino next to the computer by selecting an appropriate length parallel cable, of which I have hoarded many over the years.
http://paulckruger.com/cnc-machines.html
Old fart with more ideas than are useful. CNC Newbie, be gentle.
* Shapeoko 2
* PrintrBot
* Aprox 2.38 tons of tools
* Sears Tractor being modified as a woods buggy
* Bunch of lasers
http://www.paulckruger.com
Re: Stepper motors vibrating
Post by WillAdams » Mon Jun 23, 2014 3:23 pm
Very, very cool (using the printer cable to connect things).
It actually makes for an interesting idea --- connect one controller to multiple machines (or multiple controllers to a single machine) and use a A/B printer switch box (remember those?) to switch between them --- would that work, or would it be too electrically noisy?
I'm envisioning a near future where I want to be able to switch my Shapeoko 2 from the Arduino/gShield to an Azteeg X5 mini and back, so that's something I'll have to keep in mind if it's feasible.
PaulKruger
Post by PaulKruger » Mon Jun 23, 2014 7:37 pm
I don't think noise would be as much a problem for servos as it would have been for printers. Both "plot" and both typically used servos so what would work for a printer should work as well for CNC servos.
Short term I just like things that unplug when not used.
Long term, I may buy / build another machine and dedicate that one to a laser cutter application. One box for both so don't need to duplicate Arduino and Shield.
I don't have another AB switch but I don't really see the need when I can just switch a plug.
Nigel K Tolley
Post by Nigel K Tolley » Sat Jun 28, 2014 4:10 pm
That might be a great idea for the hackspace to save some money on the homebrew machines members make. I even donated one of those switch boxes a while back.
