Cant get nema 23 to fit
awesomename
Post by awesomename » Fri Mar 21, 2014 5:03 pm
I just don't have enough clearance between the makerslide x axis rails and the top bolts of the nema 23 motors. and now that the y axis motors sit so low, I am really concerned the idler pulleys are not going to keep much tension.
Re: Cant get nema 23 to fit
Post by cvoinescu » Fri Mar 21, 2014 5:16 pm
Move the MakerSlide all the way to the back of that slot, and the bolt heads for the NEMA23 motors should just fit.
Or notch the rail, as at least one other Shapeoko 2 owner has done -- you don't need the last centimetre or so of V rail anyway, the V-wheels can't get there.
chambrot
Post by chambrot » Fri Mar 21, 2014 8:22 pm
Thats what I did, I cut a notch into mine.
Good luck.
Custom ShapeOko using original design, 1000mm MakerSlide X Axis, Double 1000mm MakerSlide Y Axis, Nema 23 on all, upgraded Z Axis, Dremel 300, controlled by TinyG
Carl Fisher
Post by Carl Fisher » Sat Mar 22, 2014 1:48 am
Interesting. Do you have a picture of where it's causing a problem?
I just mounted NEMA 23's on all axis and had no clearance issues.
skantron
Post by skantron » Sat Apr 12, 2014 9:14 pm
I've had the same problem... I pushed it all the way back but it's still interfering a bit, and making it so I can't get the x-axis makerslide totally square. I will try notching the bottom end.
- Shapeoko2 #4557, NEMA 23
CalebPeters
Post by CalebPeters » Sun Apr 13, 2014 3:03 am
Inventables just posted this blog post today.
Near the end it speaks specifically about dealing with this issue. The article contains some pictures illustrating the installation process too.
Shapeoko 2 #3164 : GRBL, NEMA 23 motors, 350W Spindle, Limit/home switches, Drag chain, X-Carve Upgrade.
DIY-Oko 3 #-1 : LinuxCNC, PC-450 with Super-Pid, Hall Effect Limit/home switches.
