Cant get nema 23 to fit
I just don't have enough clearance between the makerslide x axis rails and the top bolts of the nema 23 motors. and now that the y axis motors sit so low, I am really concerned the idler pulleys are not going to keep much tension.
Re: Cant get nema 23 to fit
Move the MakerSlide all the way to the back of that slot, and the bolt heads for the NEMA23 motors should just fit.
Or notch the rail, as at least one other Shapeoko 2 owner has done -- you don't need the last centimetre or so of V rail anyway, the V-wheels can't get there.
Thats what I did, I cut a notch into mine.
Good luck.
Good luck.
Custom ShapeOko using original design, 1000mm MakerSlide X Axis, Double 1000mm MakerSlide Y Axis, Nema 23 on all, upgraded Z Axis, Dremel 300, controlled by TinyG
Interesting. Do you have a picture of where it's causing a problem?
I just mounted NEMA 23's on all axis and had no clearance issues.
SO2 Build Log: http://www.shapeoko.com/wiki/index.php/User:Carl_Fisher
I've had the same problem... I pushed it all the way back but it's still interfering a bit, and making it so I can't get the x-axis makerslide totally square. I will try notching the bottom end.
- Shapeoko2 #4557, NEMA 23
Inventables just posted this blog post today.
Near the end it speaks specifically about dealing with this issue. The article contains some pictures illustrating the installation process too.
Shapeoko 2 #3164 : GRBL, NEMA 23 motors, 350W Spindle, Limit/home switches, Drag chain, X-Carve Upgrade.
DIY-Oko 3 #-1 : LinuxCNC, PC-450 with Super-Pid, Hall Effect Limit/home switches.
