Flexible Coupler wont go on
Auarhau
Post by Auarhau » Mon Mar 24, 2014 8:06 pm
It's too tight to fit my nema 17 shaft it seems. How tight is this supposed to be? I'm afraid to force it harder..
Re: Flexible Coupler wont go on
Post by WillAdams » Mon Mar 24, 2014 8:10 pm
Did you loosen all of the set/grub screws? You might want to completely remove them.
It's a solid chunk of aluminum --- I don't think you're likely to damage it --- just be careful of the motor.
One other thing to try would be to put the coupler into boiling water (dry it carefully) and hold the motor shaft against a piece of ice (w/o letting the motor mechanism get wet, or condensation run down the shaft).
Post by edwardrford » Mon Mar 24, 2014 8:11 pm
Sorry you're having this problem. here are a couple of possible solutions:
1.) make sure the screws are all the way loose on your coupler
2.) Start from a slight angle and try to rock the coupler onto the motor shaft
3.) make sure there are no burrs on the inside of the coupler
4.) With some finesse, use a straight blade screwdriver to slightly open up the coupler end
Auarhau
Post by Auarhau » Mon Mar 24, 2014 8:28 pm
Yeah I did remove all the screws. I measured the shaft and the coupler now (4,99mm shaft diameter and 4,89mm coupler diameter). It's 0.1mm off. I tried to pry it open at the end with a screw driver, and pressed and rocked it on as hard as I dare. I can see the motor shaft has widened the coupler at the opening. Seems like I almost got it in 0.5mm and the result is tiny thin aluminium rings were shaven off the inside of the coupler.
I am tempted to try to drill it larger, or turn some sandpaper down there.. Bad idea?
How far am I supposed to press the coupler down on the shaft by the way? Docs only say to put it on.
RobCee
Post by RobCee » Mon Mar 24, 2014 8:32 pm
If you can get access to one, a reamer would be better (more accurate) than a drill. But maybe you could gently twist a drill in it by hand?
RC - Tapatalk
Post by WillAdams » Mon Mar 24, 2014 8:36 pm
Compare it to the lengths of the M3 stand-offs.
The length of motor shaft inserted should be:
- enough for the coupler to grip firmly
- less than half the length of the coupler
A drill would be my inclination as well --- I believe the whole assembly is flexible enough that it'll ``just work'' once you're done, but agree w/ RobCee that doing it carefully and slowly by hand would be best.
Before you do so --- have you checked to see if the M8 rod fits as well?
Post by edwardrford » Mon Mar 24, 2014 8:39 pm
The other thing you could do is run an M5 screw through it. I'm thinking the threads might knock off/down any burrs that could be preventing the motor shaft from sliding in. It would be akin to a small file :-)
Auarhau
Post by Auarhau » Mon Mar 24, 2014 8:40 pm
Yeah the 8mm rod threaded in as far as the 5mm neck on the opposite end, so that's good:) I haven't got a reamer, but I will try to improvise then
Auarhau
Post by Auarhau » Mon Mar 24, 2014 9:10 pm
Got it on now!
What did the trick was a combination of the suggestions here and some MacGyver'ing 8-)
I roughed up the back end of a old 5mm drill bit with some coarse sandpaper and made my own ultra ghetto "reamer". With a flat screwdriver inserted in the slot on the end of the coupler, and gripping my ghetto reamer with some mole grips I was able to turn it back and forth until I got through. It worked kind of like a very round very fine file. And I could use more force with the stepper motor out of the equation.I just hope it's still straight enough. I don't think I will have problems with the coupler slipping on me though:p
Thanks for all the helpful suggestions!
