Rhythmic thumping on x axis
cmason
Post by cmason » Sun Jan 18, 2015 4:56 am
I've noticed that on my ~ 1 year old Shapeoko 2 there's something going on with my x-axis where it makes a thumping noise at one particular spot on the rotation (ie every rotation, not at a particular spot on the Makerslide). It feels as though there's a flat spot on one of the V wheels. However I cleaned and inspected them all carefully (while still on the machine) and can't see any damage. I also looked at the Makerslide and it seems visually ok. The rotation "pops" into that spot when I move the carriage manually. That is: it takes more force (not dramatically more) to start it moving from that spot on the rotation. When I rapid the machine I can feel it thumping once per rotation. It still seems to work ok; I was able to cut a 15 min job at 60 in/min with no noticeable problems. I'm wondering if this could be bearing related? Any suggestions for identifying which one?
-c
AlBorland
Re: Rhythmic thumping on x axis
Post by AlBorland » Sun Jan 18, 2015 12:11 pm
I had one wheel pair on the X axis too tight, and when I came back from a one-month trip, it exhibited exactly the behavior you described. But after a few days of using the machine the thumping was gone.
Look on the bright side: You could add a rhythm track to http://www.shapeoko.com/forum/viewtopic.php?f=30&t=5033 ;-)
tjshape
Post by tjshape » Sun Jan 18, 2015 1:00 pm
If you disconnect the x axis motor from the controller completely, does the thumping still occur when manually moving it?
Shapeoko 2, ACME upgrade, Belt Drive Z-Axis upgrade, Dewalt DW660
Post by cvoinescu » Sun Jan 18, 2015 3:43 pm
That can happen if you let the machine sit for a while, with the V-wheels very tight. The V-wheels will get little flats where they press against the rail. The good news is that they're not permanent: the Delrin will slowly bounce back over the course of a day or two as you resume using the machine.
halfnormal
Post by halfnormal » Sun Jan 18, 2015 4:14 pm
Had exactly the same symptoms, did everything you did and could not find the problem. I re-adjusted the tension and the problem went away.
cmason
Post by cmason » Sun Jan 18, 2015 10:08 pm
Thanks all. Does seem to be getting better.
-c
