hello, world printing in portrait
DRUMSZ
Re: hello, world printing in portrait
Post by DRUMSZ » Sun Feb 08, 2015 1:04 am
thanks all
so when i swap the y and x on the board it still is not right or do i have to swap some pairs ....
sorry to bother all you with this but dam i thought wiring up an rc heli cyclic was confusing
Caesar S
Post by Caesar S » Sun Feb 08, 2015 2:45 am
We've all been there with you :D take a breather and come back to it tomorrow.
What specifically runs into what rail?
Also any chance you can post a video (e.g. from a cell phone)?
Post by cvoinescu » Sun Feb 08, 2015 3:21 am
Yes. To reverse the direction of an axis, swap the wires of one pair (just one pair, not both!).
DRUMSZ
Post by DRUMSZ » Sun Feb 08, 2015 1:33 pm
Thanks to all for the replies
went back and read thru it again and to my dismay uuhh and I have also found another Easter egg axis it is L and I have labeled my forehead with it
so I should just swap it on the stepper board and have no troubles
has anyone reversed an axis seems my z is backwards also tried the blue and green but it didn't like that. did not run even close to as smooth as the backward wiring
Post by WillAdams » Sun Feb 08, 2015 1:50 pm
http://docs.shapeoko.com/helloworld.html
If one has started with the suggested value of
$6=28
Then if the Z-axis is reversed you should enter
$6=156
c.f. http://www.shapeoko.com/wiki/index.php/Grbl#Invert_Bits
DRUMSZ
Post by DRUMSZ » Sun Feb 08, 2015 2:00 pm
and I would type that in the command box ? will it be saved or do I issue another command ?
Post by edwardrford » Sun Feb 08, 2015 3:26 pm
Yes, just type that into the command box. I like to hit the reset button on the arduino, just to make sure it persists, but I don't think that's necessary.
Caesar S
Post by Caesar S » Sun Feb 08, 2015 4:49 pm
DRUMSZ wrote: has anyone reversed an axis seems my z is backwards also tried the blue and green but it didn't like that. did not run even close to as smooth as the backward wiring
Blue and green belong to separate coils. They won't reverse the direction of the motor.
You'll want to swap black and green, or red and blue.
Hope this helps.
DRUMSZ
Post by DRUMSZ » Sun Feb 08, 2015 5:45 pm
you guys are the best !!!!!
used the command to swap z worked like a charm
now the x is reversed and after that it should be fine I know I saw the command will look around for it
again thanks for putting up with the redundant questions
this is why I went with the shapeoko the user community is the best !!!!
DRUMSZ
Post by DRUMSZ » Sun Feb 08, 2015 9:41 pm
with your help the out come !!!!!!!!!!
yes I held the sharpie just to the rail after seeing the s but happy with the results
THANK YOU ALL !!!!!!!!!!!!
now how do I save the home position......... more reading :D
