First Start Up?
Caesar S
Re: First Start Up?
Post by Caesar S » Wed Feb 11, 2015 2:50 am
OK, that's good! It means your computer is not connected to the Arduino UNO and nothing is toast (yet).
Now, connect UGS to a different COM port (you're using Windows right?), make sure the baud rate is 9600.
Keep connecting to subsequent COM ports until you see Arduino respond with "grbl 0.8c"
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Wed Feb 11, 2015 2:55 am
Caesar S wrote:OK, that's good! It means your computer is not connected to the Arduino UNO and nothing is toast (yet).
Ok that got me the "grbl 0.8c" Should i be able to move the axis by the machine control in UGS?
Shapeoko 2 #8233
Caesar S
Re: First Start Up?
Post by Caesar S » Wed Feb 11, 2015 2:57 am
Yes!!!!
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Wed Feb 11, 2015 2:59 am
Still nothing moving....
Shapeoko 2 #8233
Caesar S
Re: First Start Up?
Post by Caesar S » Wed Feb 11, 2015 3:02 am
Does the gshield have 24VDC power connected?
Gently try pushing the x or y axis, do they give? or resist?
If they resist, that's good, they have power. If they give, that means they might not have power or not energized to hold position.
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Wed Feb 11, 2015 3:04 am
They are not resisting,Yes the g shield is connected to 24 volt
Shapeoko 2 #8233
Caesar S
Re: First Start Up?
Post by Caesar S » Wed Feb 11, 2015 3:06 am
OK, are you sure the gshield have 24VDC power?
If so, with everything powered off, check the wiring. Using a multimeter test the wire connections from the gshield to the stepper motors. Also make sure the cables are connected to the right connection point.
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Wed Feb 11, 2015 3:08 am
Am i just checking for continuity?
Shapeoko 2 #8233
Caesar S
Re: First Start Up?
Post by Caesar S » Wed Feb 11, 2015 3:09 am
Yes, just for continuity.
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Wed Feb 11, 2015 3:14 am
Thats not going to be so simple....I didnt want to use the junction blocks so EVERYTHING is soldered :o So technically i should just be able to cross the pairs and check for resistance?
Shapeoko 2 #8233
