First Start Up?
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Sat Feb 14, 2015 3:45 am
Ran the Hello World ok...Except for me downloading the Inches file then selecting metric....had hand on the button though but it got the marker.... :D
Shapeoko 2 #8233
Damin69
Re: First Start Up?
Post by Damin69 » Sat Feb 14, 2015 4:24 am
It looks very good. Bet it feels good.
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Sat Feb 14, 2015 4:55 am
Sure does....Thank you everyone for your help.....I will be fine tuning it very soon so I'm sure there are more questions to come.....
Shapeoko 2 #8233
clockit
Re: First Start Up?
Post by clockit » Sat Feb 14, 2015 5:31 am
it's hard to tell from the angle of the video, but, your gantry is moving to much... are your x rails pushed together? with the spacers provided to assemble the x motor plates there should be about an 1/8" gap between the doubled x rails... also, you may want to double check your v wheel adjustment, if they're not adjusted properly it will allow your gantry to 'rock'...
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Sat Feb 14, 2015 12:39 pm
There is roughly a 1/8 gap between the double rails......My v wheels are tightened to the point is a little stiff to move.....I can't find what is causing that wobble
Shapeoko 2 #8233
clockit
Re: First Start Up?
Post by clockit » Sat Feb 14, 2015 4:47 pm
one other thing that you can check is if the 2 bottom bolts on the z rail or tight. If you put the insertion nuts in upside down during assembly they don't seem to tighten as well, sounds werid but I had the issue. Also, while assembled, its easier to tighten them if you insert your hex wrench through the inspection hole of the back x plate.
After that, being a newbie myself, that's all I got. Sorry, hope you figure it out, because even if it's not part of the noise I don't think you'll be happy with you routing when cutting thicker or stronger materials...
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Sat Feb 14, 2015 10:09 pm
I've gone over the entire machine once again and nothing is loose.....I did notice the table it is on wobbles a little....staying to think it is an optical illusion......
Shapeoko 2 #8233
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Sat Feb 14, 2015 10:12 pm
My wife gets all the first parts off my machines.....Just did this quickly with my Daughter on Easle and let my daughter paint it........
Shapeoko 2 #8233
Caesar S
Re: First Start Up?
Post by Caesar S » Sun Feb 15, 2015 1:34 am
Very cool, glad to see you made it :) Welcome aboard.
I see the O's are not perfect ... but you'll fix it I'm sure :lol:
mikenmel08
Re: First Start Up?
Post by mikenmel08 » Mon Feb 16, 2015 5:40 pm
You are correct sir.....I want it running perfectly....I Recieved my kit 2 weeks sooner than I was expecting so I put my laser cutter project on hold.....Now that the shapeoko is running I will go back to the laser four a little bit......Thank you for all your help and in sure I will require more of it.....
Mike
Shapeoko 2 #8233
