Acme upgrade, Nema 23 Z upgrades and Tiny G installed.
Targus
Post by Targus » Fri Apr 10, 2015 3:28 pm
It's finally warm enough to get back out in the garage. In this video, I upgrade the Z axis on the Shapeoko 2 with the Acme upgrade, Belt drive Z-axis kit, and NEMA 23 stepper motor. These upgrades are fantastic. I will be able to move my router closer to the gantry, and the Acme upgrade is super smooth. Next up, more NEMA 23s and tiny G.
Acme Upgrade: http://shop.shapeoko.com/collections/fr ... -upgrade-1
Belt Drive NEMA 23 Z-Axis Kit: http://shop.shapeoko.com/collections/fr ... z-axis-kit
NEMA 23 stepper motors: https://www.inventables.com/technologie ... or-nema-23
Damin69
Re: Acme upgrade, Belt Drive, and Nema 23 Z upgrades install
Post by Damin69 » Fri Apr 10, 2015 6:53 pm
good Job. You will really like the upgrade. I am glad that when I did the build from the start We tapped the Z makerslide on both ends. This made of an easy upgrade as I did not have to take the Makerslide off of the plate to do the upgrade.
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
Brian Stone
Post by Brian Stone » Fri Apr 10, 2015 7:28 pm
Here here. The Acme Z-axis screw was one of the best upgrades I've done to the machine.
Shapeoko 2 #7353
Targus
Post by Targus » Wed Apr 15, 2015 1:27 pm
i have been playing around with the machine. I have all the NEMA 23s hooked up a working. I thought i would not have to take the CNC apart to install the NEMA 23s ... boy was i wrong. The NEMA 17s came off without disassemble, but the hole locations for the 23s were overlapped by the makerslides. Was not hard, just took a lot longer to do, and i had to re-square the machine again. All is all i have very happy with the upgrades so far. It cuts like butter. I can't wait to get the TinyG up and running. Just waiting on some more stepper motor wiring (it should be delivered tomorrow).
Targus
Re: Acme upgrade, Nema 23 Z upgrades and Tiny G installed.
Post by Targus » Wed Apr 22, 2015 4:08 pm
I got the tiny G. It was a bit confusing to set up and the instructions were not very clear in a lot of steps. But finally, after a few hours of getting it hooked up and settings set, it works and it works great. Ill post up a video later in the week.
kristenanne77
Post by kristenanne77 » Tue Jan 03, 2017 4:11 am
Targus wrote:It's finally warm enough to get back out in the garage. In this video, I upgrade the Z axis on the Shapeoko 2 with the Acme upgrade, Belt drive Z-axis kit, and NEMA 23 stepper motor. These upgrades are fantastic. I will be able to move my router closer to the gantry, and the Acme upgrade is super smooth. Next up, more NEMA 23s and tiny G.
I have the Acme screw upgrade and was looking for the Z axis pully system you have so I can mount the router closer to then Z axis.
The link doesn't work so I am guessing they dont make it anymore.
If a kit is not available, can you provide me with info on whare I can get the specs and parts to do this?
K
Damin69
Post by Damin69 » Wed Jan 04, 2017 3:55 am
You could try getting hold of Improbable Construction and see if he has any left over parts for them as he was the one selling them. Or he may have a source for parts you need. I know he has the cad file you could use to make the plate out of aluminum. After the Plate all you need is some standoffs, Bolts, Pulleys and Belt.
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
