Carbon Fiber Plates and Aluminum Bearing Blocks
Post by Improbable Construct » Wed Feb 27, 2013 12:13 am
I went a bit crazy today and made some changes to my Shapeoko.
First I made some Carbon Fiber motor plates.
Carbon Fiber plate.JPG (118.61 KiB) Viewed 5178 times
They are 4mm thick and look awesome.
mounted plate.jpeg (117.42 KiB) Viewed 5178 times
I don't have any idea if they are stronger or better but they have to be faster, right?
I mean, look, carbon fiber! They make race cars out of that stuff!]
I added a misumi 40x40 extrusion with hard coated open rail on both sides to replace my double X makerslide.
I am using the open builds steel V-wheels as well.
steel wheels.jpeg (111.5 KiB) Viewed 5178 times
I put a dial indicator on my X axis motor plate before and after and there seems to be about .020" less flex in the X axis carriage. I used my calibrated pushing hand to put pressure on the spindle.
Here are a couple of shaky videos of before and after.
Before:
After:
Last edited by Improbable Construct on Fri Mar 01, 2013 9:46 pm, edited 1 time in total.
mjohn
Re: A bunch of new upgrades.
Post by mjohn » Wed Feb 27, 2013 3:40 am
Fancy, I love it!
Put a Neuspeed sticker on it too, that's guaranteed to raise the RPM's by a thousand or two.
PsyKo
Post by PsyKo » Wed Feb 27, 2013 7:26 am
Is it also double open rail on the X axis ? 40x40 misumi with OR edge on both side ?
Would you recommand Open Rail instead of Makerslide ?
Shapeoko #736
Tom Smith
Post by Tom Smith » Wed Feb 27, 2013 4:39 pm
Interesting, so do you find the cf compares well to the steel during operation? Do things vibrate more with the lighter weight?
Tom
_______________
ShapeOko1 191
deejayspinz
Post by deejayspinz » Wed Feb 27, 2013 5:58 pm
Very nice IC... Carbon fibre.... drrrrruuuulllll...
Post by Improbable Construct » Wed Feb 27, 2013 6:30 pm
PsyKo wrote:Is it also double open rail on the X axis ? 40x40 misumi with OR edge on both side ?
It is double open rail on the X. I ordered 1000mm of 40x40 and 4 1000mm sticks of hard coated OpenRail.
I don't really know how it is going to hold up but the steel wheels work really well.
I went with the OpenRail because it was way cheaper than the local quote I got to have my Makerslide hard coated.
They wanted over $100.00 and two weeks to do it.
The new setup seems to have eliminated a fair amount of the Z-Axis twist on the X-axis.
Tom Smith wrote:Interesting, so do you find the cf compares well to the steel during operation? Do things vibrate more with the lighter weight?
Tom
The new plates are quite a bit lighter than the steel ones. CF=0.8 lbs Steel=2.65 lbs
The weight loss is more or less mitigated by the increase of weight in the 40x40 and open rail. 2x1000 mm of Makerslide=3.12 lbs 40x40 + 4x1000 mm OpenRail=4.8 lbs
So that gives a net increase of .17 lbs.
In theory the CF should dampen the vibration, but I really never had a problem with vibration. (Although I think my DW660 is about to die. It sorta sounds like it is starting to spin a bearing, so it is vibrating a bit more than it should.)
I haven't had a chance to run a job yet but I should be able to comment on the performance in the next day or too.
Post by Improbable Construct » Fri Mar 01, 2013 9:32 pm
So I decided to put my new carbon fiber motor plates to the test.
First I milled a new standard carrier plate out of carbon fiber.
I don't know if it is a gain in stiffness but is was most certainly not a loss. :)
And besides its freaking carbon fiber!
Anyway that all went well, so I decided to try and mill some 10mm 6160 aluminum plate.
I made a NEMA 23 bearing block / motor mount for my Z-axis.
I ran it at:
400 mm/min feed
20000 RPM
1/8" four flute solid carbide endmill.
Spiral plunge
I also added lots of tap magic cutting oil throughout the milling.
The Bearing would not go into the hole on the first try.
I used the settings for plastic and obviously the aluminum would not flex to allow the bearing to seat.
So I had to run the end mill around again taking off .05 mm.
It worked perfectly and the bearing slides right in with just a bit of effort.
I modified the bottom block to remove unnecessary holes and rounded off the end.
Pictures:
aluminum bearing blocks.jpeg (118.24 KiB) Viewed 4966 times
Here are the finished blocks. I also flipped the bottom block and cut counter sinks for the screw heads.
Aluminum and carbon fiber.jpeg (128.18 KiB) Viewed 4966 times
Here are the finished X and Z axis with the carbon fiber motor plate and standard carrier plate.
The aluminum bearing blocks can also be seen.
Last edited by Improbable Construct on Mon Mar 18, 2013 8:03 pm, edited 1 time in total.
Re: Carbon Fiber Plates and Aluminum Bearing Blocks
Post by cvoinescu » Fri Mar 01, 2013 10:42 pm
I am literally drooling here (but it could be that I was thinking of pear tart just before I read your post).
Tom Smith
Post by Tom Smith » Fri Mar 01, 2013 10:59 pm
Yeah, that looks nice and all, but it really needs some pinstripes...
j/k, that looks awesome, and very inspiring!
Tom
_______________
ShapeOko1 191
PsyKo
Post by PsyKo » Fri Mar 01, 2013 11:37 pm
Improbable Construct wrote: I made a NEMA 23 bearing block / motor mount for my Z-axis.
I ran it at:
400 mm/min feed
20000 RPM
Spiral plunge
Any information about the pass depth ??
I'm about to mill some aluminium tomorrow :)
Shapeoko #736
