Wooden Cable Chain
teddy92
Wooden Cable Chain
Post by teddy92 » Tue Mar 05, 2013 9:25 am
Hi!
i found a very nice solution to the cable management! I thought many of you would be interested in this...
I didn't make this yet because my eShapeoko didn't arrive yet but as soon as i do, I will post some photos.
All credits go to Roger Quintero, designer of this chain.
http://www.youtube.com/watch?v=JAWcicckaMA
zerblatt007
Re: Wooden Cable Chain
Post by zerblatt007 » Tue Mar 05, 2013 9:50 am
That was pretty cool actually.. :)
Will Winder
Post by Will Winder » Tue Mar 05, 2013 2:45 pm
I found the files for this over here (I haven't actually made an account to download them though): http://www.phlatforum.com/viewtopic.php?f=206&p=42477
phlamingo
Post by phlamingo » Tue Mar 05, 2013 4:39 pm
Would those side plates fall off after a while, when the motion loosens up the friction fit?
ShapeOko Batch 2, Number 571, dual-Y motors, Y belts outside, odd anchors. Not operational at the moment: needs rewiring.
glendresser
Post by glendresser » Tue Mar 05, 2013 7:41 pm
For anyone looking for the dxf files, they're posted here:
http://www.cnczone.com/forums/videos/17 ... ost1244105
Looks like an interesting design, I'm going to give it a try.
ejs
Post by ejs » Thu Mar 14, 2013 3:58 am
phlamingo wrote:Would those side plates fall off after a while, when the motion loosens up the friction fit?
I thought the same thing at first. But if you notice, it's put together a bit like a brain teaser puzzle. In the design, the cross members are actually holding in the tips of the side plates once the next link is assembled. It's actually a mechanical lock rather than a friction fit.
