Vacuum clamps
zerblatt007
Vacuum clamps
Post by zerblatt007 » Tue Mar 19, 2013 11:21 am
This would probably not fit every job, but could it be a usable mount alternative?
http://www.youtube.com/watch?v=Z_azh7RczPk
It does not seem very expensive either..
http://www.ebay.com/itm/VACUUM-CLAMPS-P ... 3f0dfdf18b
Anybody tried these Vacuum Clamps with the ShapeOko?
Would it be difficult to avoid saw dust getting into the pump and destroy it?
Re: Vacuum clamps
Post by cvoinescu » Tue Mar 19, 2013 12:34 pm
Those vacuum clamps look very nice. There are many other options, and professionals use similar devices. Here's one example. There are smaller models too, of course. You have a ShapeOko, you can make your own vacuum clamps!
DanMc
Re: Vacuum clamps
Post by DanMc » Tue Mar 19, 2013 5:28 pm
That's a pretty good price, it's hard to find a vacuum venturi by itself for under $50.
There is no vacuum per se on the ones you linked to, it's a venturi which generates vacuum from compressed air. You would need a compressor but no worries about dust in pumps.
zerblatt007
Re: Vacuum clamps
Post by zerblatt007 » Wed Mar 20, 2013 9:25 am
DanMc wrote:There is no vacuum per se on the ones you linked to, it's a venturi which generates vacuum from compressed air. You would need a compressor but no worries about dust in pumps.
Ah, ok - thanks. So that is what venturi means..
I was searching for the picture of the compressor as I thought that was what venturi was.. :-/
But I tiny compressor should do the trick then?
Cwalster
Re: Vacuum clamps
Post by Cwalster » Wed Mar 20, 2013 5:15 pm
Venturis usually require a fairly high amount of compressed air. I would contact the seller about the cfm requirement before you start sizing your compressor.
