Is this thing even a Shapeoko anymore?
Improbable Construct
Re: Is this thing even a Shapeoko anymore?
Post by Improbable Construct » Fri Mar 29, 2013 2:08 pm
northbear wrote: Did you need to press the bearings into the metal V wheels? Do you think it the fit between the bearing and the V wheel or the material (steel vs delrin) that helped more? Or was it the "wider" design of the OpenBuild V wheels? I like that the OpenBuild V wheels (both metal and delrin) cover more of the bearing width which should be an advantage. Probably impossible questions to answer, I know! But I am debating the steel vs delrin question and thought I would ask!
** not really official - just something I wrote
The bearings were a nice tight fit into the metal wheels.
They just sort of slid in but feel very tight and stable.
I like them a lot.
I think the wider wheels do help somewhat with the rigidity.
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
northbear
Post by northbear » Fri Mar 29, 2013 3:57 pm
Improbable Construct wrote: The bearings were a nice tight fit into the metal wheels.
I like them a lot.
Thanks for the response and feedback! Again very nice upgrades on your machine and appreciate you taking the time to share your experiences!
My buildlog is here
Post by twforeman » Fri Mar 29, 2013 6:57 pm
Another question, where did you get the steel V wheels?
Thanks again.
Ender 3 3D Printer
northbear
Post by northbear » Fri Mar 29, 2013 7:25 pm
twforeman wrote:Another question, where did you get the steel V wheels?
Thanks again.
Believe it was from here:
http://www.openbuilds.com/OpenBuilds_St ... rome-steel
My buildlog is here
Post by Improbable Construct » Fri Mar 29, 2013 7:31 pm
Thanks again.
That is correct.
Shapeoko 3 # 0003
Store:
Twitter:
baz
Post by baz » Mon Apr 01, 2013 4:09 pm
Impressive build IC.
My machine (almost complete, pictures to come soon!) is very similar to yours, 800 x 1200 with steel wheels and black hardened MakerSlide (being part of MakerSlide Europe has its perks :D ), sans the carbon fibre and tall x axis. I have opted for nema 17's all-round except the x axis that will have a 23. I am using a Kress 800, so the weight isn't colossal but I figured that the two nema 17's on the y axis will be well up to the job. Due to availability and cost I have got a load of t2.5 belt along with some aluminium pulleys (that I will bore out accordingly), I also figured the steel cored belt will fare a bit better than the neoprene MXL belt, similarly with the aluminium pulleys over the small plastic ones. My question for you is; what are your experiences with the belt drive train on a larger (heavier) machine? What type do you currently use?
Baz
ShapeOko #676, eShapeOko #11, Hardened MakerSlide, OpenRail, Steel v's, Misumi Extrusion, Kress 800
MakerSlide Europe Store
Post by Improbable Construct » Mon Apr 01, 2013 5:58 pm
I am still using the MXL belts. They seem to be holding up okay.
I do have some cord separation on the edge of one belt on one side but I think that was due to a idler pulley that had slipped off its bearings and was rubbing hard on the edge.
Shapeoko 3 # 0003
Store:
Twitter:
willo
Post by willo » Sat Apr 06, 2013 4:31 pm
Dammit IC, I get busy for a few months and come back to find this. That is some fantastic work sir!
Are those shopbot/mechmate v-wheel bearings? Excellent! How are they working out for you?
Edit: Nevermind, I see, openbuild. Still, how are they?
Post by Improbable Construct » Sat Apr 06, 2013 6:44 pm
They work really well. I think the ones that Bart sells on the buildlog store are probably better, but these are half the price and are the same size as the Delrin wheels.
Shapeoko 3 # 0003
Store:
Twitter:
willo
Post by willo » Sun Apr 07, 2013 3:16 pm
Did you just buy the metal v wheel and use your existing bearings/spacer or did you buy the wheel kits?
