Is this thing even a Shapeoko anymore?
Re: Is this thing even a Shapeoko anymore?
I bought the kits, but that was because the wheel only kits were sold out at the time I placed my order.
Very nice build. I skipped building the original ShapeOko and went to one with a 32" x 48" cutting size. I haven't done many of the upgrades you have but I definitely want to build up the gantry and my Z as that is the biggest flex I have.
I saw your video of cutting the Delrin with the 2 flute carbide bit. I thought those worked pretty well until I found an "O bit single flute" carbide bit. They are designed for plastic and are the BOMB! Then work very well and are also quiet. So far I have only cut
I got mine on eBay for $4/ea new and they showed up in two days to Chicago. I highly recommend them for soft plastics.
http://www.ebay.com/itm/380556540906?
Here is a photo of the results.
- Attachments
- The holes on the left are right after cutting. This is .125" thick Sintra PVC sign board
- 2flute-vs-1flute.jpg (83.37 KiB) Viewed 1243 times
That's quite a big difference, but I don't believe it's the single flute vs. two flutes aspect of it, but rather the fact that the second bit is designed specifically for soft plastics. I've ordered a two-flute endmill for plastic from the same guy, and it's on its way to me. I'll report on it when I get around to using it.
