My $0.99 dust shoe
potatotron
My $0.99 dust shoe
Post by potatotron » Mon Apr 08, 2013 2:46 am
My original plan for my new mill was to buy one of IC's dust shoes because his ACME rod and Dewalt mount kits are top notch, but unfortunately I can't afford the loss of the Y axis millable space.
Within the last few weeks there's been discussion on dust shoes and the drawback that the bristles obscure your view of the milling, so here's my workaround: clear tape and a soda bottle.
I made several mockups with paper to get the holes for the vacuum and router sized and placed correctly, then cut that template out of a $0.99 bottle of Cactus Cooler from Ralph's. I used clear packing tape to hold the sides together, then more on the bottom edge, folded on itself then sliced into 1/8" fingers.
I just finished assembly of my new mill today and have only made three cuts but so far so good. I'll post again in a week or so with an update.
Screen Shot 2013-04-07 at 7.34.25 PM.png (43.45 KiB) Viewed 4721 times
DSC_0013 2.JPG (159.68 KiB) Viewed 4721 times
Re: My $0.99 dust shoe
Post by twforeman » Mon Apr 08, 2013 1:07 pm
Clever. Let us know how it works out!
danimal
Post by danimal » Sat Apr 20, 2013 10:59 pm
I moved my dust shoe off to the side of my 660 like that too. I used a vacuum piece from a belt sander that I bought from good will and connected a piece of tubing to it that I got from ace hardware. I think that the whole thing cost me about $12 to make. I am going to make a little U shaped piece to hold the top section of the vacuum port to the 660 mount, but I am in no hurry because it seems to be working just fine with the zip tie. :D
For now I am just using paper towels cut into a ribbon strips and the two sided tape that cam in the kit to make a little skirt for the lower plastic piece. It seems to hold on there just fine and they last for quite a while if you don't take them off and on frequently. I just needed a quick solution because the 660 throws chips far and wide. I am going to make a permanent one out of craft foam when I feel the need.
Shapeoko # 1458
potatotron
Post by potatotron » Fri May 10, 2013 2:28 am
Hi everybody,
I've been using my ultracheap dust shoe for a few weeks now and so far so good. Here it is in action:
http://www.youtube.com/watch?v=Smoe_385paY
bjbsquared
Post by bjbsquared » Fri May 10, 2013 11:50 am
Awesome.
I will be doing this myself so look forward to questions lol.
