1/4" spacer alternatives / sources
Post by WillAdams » Thu May 09, 2013 9:35 pm
Any ideas?
I pulled apart my machine and most of the nylon spacers were visibly distorted, one so much it's got to be photographed for the wiki.
I bought some 1/2" spacers for some reason at Home Depot or Lowes, but they're too small a bore --- don't recall their having # 10...
Need an inspired suggestion to save me from a trip to the hardware store.
Re: 1/4" spacer alternatives / sources
Post by cvoinescu » Thu May 09, 2013 10:06 pm
Nominally, #10 is a bit too small for M5, but the spacers are often manufactured with enough wiggle room, and M5 is rarely a full 5.00 mm, so they fit (but fairly tightly, which is a good thing). Most of the time you'll get away with it, especially with nylon spacers, but sometimes you won't. I have a small bag of aluminum #10 spacers with an I.D. of exactly 0.192"... which is a shame, really: I can't use them because they're made too well.
Tom Smith
Post by Tom Smith » Thu May 09, 2013 10:26 pm
WillAdams wrote:Need an inspired suggestion to save me from a trip to the hardware store.
Not sure about inspired, but...
If you don't have it already, get a box of washers. they come in handy for all kinds of stuff, like, for example, stacking over a bolt to provide about 1/4" of spacing...
Tom
_______________
ShapeOko1 191
northbear
Post by northbear » Fri May 10, 2013 2:42 am
WillAdams wrote: don't recall their having # 10...
See if they have a #12 at the hardware store, like mcmaster part # 92510A662 which as an ID of 0.218" (5.54mm)
Another option is to buy them from Openbuilds for $.30 each (http://www.openbuildspartstore.com/aluminum-spacer/)
My buildlog is here
Post by WillAdams » Fri May 10, 2013 3:20 am
Broke down and went to the hardware store since I wanted a side vise. Got 4 #10x5/16" x 1/4" aluminum spacers --- started assembling the machine and realized I should've bought 10, then decided I'd leave 4 nylon spacers in place, then figured out that for one pair 1/4" was too much, so used a stack of washers as in Tom Smith's suggestion, so I'm good.
Wasn't able to use the 75mm Socket cap screws, per cvoinescu's observation, but the 70mm pan head screws I initially used worked fine, so it's all together, except that I'm somehow short one 30mm SCS (or for some reason, I'm using longer ones?).
Rule #9.
Will take a bolt and try to get a match and investigate tomorrow. And it seems I'm short, and apparently I grabbed 25mm instead of 30mm on my previous run to True Value...
Post by twforeman » Fri May 10, 2013 2:44 pm
I just bought some at McMaster-Carr. They are metric, so they are not really 1/4", but they have 6mm high spacers which are .236" so I think that will be close enough.
Post by WillAdams » Fri May 10, 2013 3:24 pm
Yeah, metric would probably be better --- there's another wish for ``ShapeOko Mk. II'' --- all metric hardware.
Will Winder
Post by Will Winder » Fri May 10, 2013 11:03 pm
I bought a bunch of #10 spacers for a "Y-axis motors on the outside" mod, which were too small for the M5 bolts holding the nema23 motors.
I ended up tapping the full length of the spacers and it worked great.
Post by WillAdams » Sat May 11, 2013 12:13 am
Tapping is a good strategy to enlarge them --- I was actually contemplating using successively larger taps to make a 13/16" bearing fit a mount plate before I got a tapered reamer.
Post by edwardrford » Sun May 12, 2013 6:43 pm
Just an FYI: I put both #10 and #12 aluminum spacers in the inventables store a while back. IMO, they're nicely priced at $0.26/pc when bought in a 10 pack
https://www.inventables.com/technologie ... um-spacers
