Dremel dust collection using threaded part
Re: Dremel dust collection using threaded part
Post by WillAdams » Sun May 26, 2013 12:50 am
Success, I believe:
I was able to get it printed @ Staples for $0.99 --- will cut and assemble next.
dustshoe.pdf
(3.65 KiB) Downloaded 211 times
99¢ Dust Shoe
Post by WillAdams » Sun May 26, 2013 6:33 pm
Success!
Cut out:
Installed:
Will try it out after nap time.
It probably would've been better to use something softer and more flexible (a sheet protector?). Also, a crevice tool would be a better choice size-wise, but would require more measuring to cut the fitting which holds the dust shoe to the vacuum than I was inclined to mess up.
Post by WillAdams » Wed May 29, 2013 12:52 am
Finally got to try it out now --- works quite well, vacuum doesn't need to be full tilt (collapses the contraption --- need to see if an elbow or something will help) only a few flecks of dust about.
Post by WillAdams » Thu May 30, 2013 3:51 pm
and last night I epoxied in an elbow and will try that when I next get a chance.
Tobias
Post by Tobias » Fri May 31, 2013 2:30 pm
Looks really nice and clean! I have to ask though, how is the vacuum doing? I hope you can adjust it lower now that it's less space to "vacuum"? And how does it react when going really low in Z, does it get entangled in the mill? Or can it?
ShapeOko #1758 with a few tweaks here and there.
I work as a CNC Operator (No mills, just lathes in different varities like Y axis and 5 axis), so have access to very good lathes.
Post by WillAdams » Fri May 31, 2013 2:42 pm
It works quite well when I turn the vacuum down to its lowest setting, which is nice for reducing the noise level.
I'm trying to minimize how low it projects down so as to minimize interference.
When it goes down really low along the Z-Axis, the fingers do get chewed up by the bits --- I guess I need to re-design it to have more clearance --- was concerned about losing working area though, hence the original tight fit.
Haven't tried it w/ the new reducer in place, but if it works, will probably just use it until it's too chewed up to work, then re-design --- I want it to fit on a single letter sized sheet though --- may be able to get more space by rotating it, or maybe I'll design it as two pieces which overlap.
William
Tobias
Post by Tobias » Fri May 31, 2013 3:03 pm
Cool :)
I will think about new designs as well, got some half-good ideas, I will post here later :)
kbot3d
Post by kbot3d » Sat Jun 01, 2013 5:11 pm
I am ready to design a dremel vacuum mount for my next project as suggested by Willadams. Just for those of you who need it as I use a dw660. I would like some input as to body height and width since I don't actually own a dremel to measure off or really need one. I have a cheap harbor frieght knock off to hobb bolts with. Your ideas would be helpful. I'm even happy to give away some prototypes to those who wish to contribute with the understanding that they give feedback, not just take the parts and go silent like some with my dw660 vac attachment. Let me know.
Tobias
Post by Tobias » Sat Jun 01, 2013 6:15 pm
Improbable Construct made a vacuum mount for the DW660 aswell, here is the link if you haven't seen it.
http://www.shapeoko.com/wiki/index.php/Dust_Shoe
He also provides both g-code and dwg files for the mount, you can take the dimensions out of there? :)
kbot3d
Post by kbot3d » Sat Jun 01, 2013 6:48 pm
I've seen it. Mine is a bit more complicated. I like to stretch the bounds of my 3d printer and make items you couldn't make any other way. That and I'm cheap and would rather spend time than money lol.
shapeoko vacuum 4 small.jpg (52.5 KiB) Viewed 3377 times
shapeoko vacuum 2 small.jpg (84.82 KiB) Viewed 3377 times
