3D Printed Dust Shoe with Quick release for DW660
dataway
Post by dataway » Thu Feb 13, 2014 8:29 pm
I just wanted to share this dust shoe I printed on my 3D printer for the DW660. I printed it up last night and put it to the test this morning cutting a sign for a friend and it works great. I especially like the quick release clip that allow you to remove the shoe quickly for a bit change. I tested cutting MDF which creates quite a bit of dust and after my cutting I am happy to say it controlled the dust very well.
You can find the dust shoe on Thingiverse
http://www.thingiverse.com/thing:231219
It took my printer approximately 2 hours to print as it requires supports. It took me another hour to to clean it up and remove all the supporting material and used some Acetone to smooth it out and seal it.
Shoe mounted on DW660
Re: 3D Printed Dust Shoe with Quick release for DW660
Post by WillAdams » Thu Feb 13, 2014 9:11 pm
Isn't that a Dewalt DW660 (not a DW611)?
If so, I guess this is after removing the quick change tool collar / it goes on in place of that?
Very clever design and I really like the toolless clip holder.
dataway
Post by dataway » Thu Feb 13, 2014 10:28 pm
Hey WillAdams,
Thanks for that clarification will, I updated the thread :D
You are correct I did remove the Quick change tool collar and this slips right over the lip of the tool in place of that collar.
chomdh
Post by chomdh » Fri Feb 14, 2014 2:17 am
Good work data way. Very nice piece. And great looking finish after the acetone treatment. What printer did you use?
Shapeoko2 #3702:
dataway
Post by dataway » Fri Feb 14, 2014 5:21 am
Thanks Chomdh, the 3D printer I use is a Printrbot Plus but has been modified from the original..I purchased it on their original kickstarter campaign.
