3D Printable 65mm Spindle Mount
zorlack
Post by zorlack » Thu Feb 20, 2014 3:39 am
I just ordered an 800W 65mm spindle. While I wait for it to arrive I designed a mounting system designed to attach the spindle to the z carriage and provide dust collection.
Check it out, it's a work in progress!
http://commonlink.blogspot.com/2014/02/ ... indle.html
or
http://www.thingiverse.com/thing:252141
zorlack
Re: 3D Printable 65mm Spindle Mount
Post by zorlack » Sat Feb 22, 2014 5:39 am
Well my spindle came in today, so I got to test-drive my mount and see how everything fit!
This video shows a bit more of the dust-collection features... although the system still needs tweaking.
AFK66
Post by AFK66 » Thu Jul 31, 2014 4:22 pm
I'm looking at the same spindle you've purchased, I was wondering if there was any way I could pay you for your time to make one of these mounts for me? I'm still a couple weeks away from mounting one, but would like to start working on getting things in order. Please let me know, I've been looking at 3d printers but haven't purchase one yet to do these sorts of mods.
Shapeoko 2 - Acme Rod/Belt Drive, Nema 23 steppers, 300 Watt Spindle - other wise stock
Shapeoko 2 inspired custom build - 1500 X 1000mm, Routakit HD Z and X axis setup, Nema 23 276oz steppers, 800 Watt Spindle, Geck 540/ Soigeneris STDR-4C controlled.
samc99us
Post by samc99us » Fri Aug 01, 2014 11:40 pm
Mount design looks good. Makerbot ABS shrink rate is variable depending on part geometry and can lead to a lot of test prints...
Which spindle did you go with??
Post by WillAdams » Sat Aug 02, 2014 1:57 am
Nice design!
Have you considered adding a mounting area for a dust skirt? I've found that having one allows me to run the vacuum at a much lower setting.
