Nema23 on Z-Axis
RobCee
Nema23 on Z-Axis
Post by RobCee » Thu Feb 27, 2014 6:32 pm
I was playing around with ideas for mounting a Nema-23 motor on my Z-Axis but didn't want to have to push my spindle out any further than it already is.
I have yet to complete the actual work, but I believe that my design is sound, for using the existing mounting arrangement for a Nema-17 motor.
Existing Nema-17 Z-Axis mounting:
Nema17
Given that the standard (Nema-17) motor is rotated by 45 degrees in order to help it avoid the other mounting hardware, I looked at the dimensions of my Nema-23. If I can turn it through the same 45 degrees, so that it's back is parallel to the Z-Axis, then it can stay on the same axis of rotation and does not take up any more Y-Axis space (if that makes sense!).
Here is my idea for mounting the Nema-23 without having to rework the Z-Axis Rail assembly:
Nema23
The adapter plate is simple enough to make from a chunk of Aluminium, I had some 3mm plate hanging around and the stock spindle was good enough to cut it out with, if slow.
Adapter plate
Nema Adapter.jpg (43.95 KiB) Viewed 3448 times
It should work if I cut down the Brass Standoffs and then use some spacers to mount the Nema-23 at a suitable distance from the plate. I think that I should still be able to get my fingers into the coupler, so that I can move the axis manually too.
RobCee
Re: Nema23 on Z-Axis
Post by RobCee » Thu Feb 27, 2014 6:33 pm
Here is a shot of the milled mounting plate:
Adapter plate
20 Adapter Plate.jpg (200.95 KiB) Viewed 3447 times
samc99us
Post by samc99us » Sun Mar 02, 2014 3:13 am
Rob I had the same thought, but lacked the time to generate a design. Would like to see your installed setup. Those are some clean cuts in aluminum, cut on the SO2?? If so, what spindle, end mill, feeds and speeds?
Post by Improbable Construct » Sun Mar 02, 2014 4:22 am
Yes that will work. It is exactly what I did for the NEMA 23 mount kit avalible in the store.
You may want to use something stronger than the brass standoffs to handle the torque of the bigger motors.
RobCee
Post by RobCee » Sun Mar 02, 2014 9:07 am
Thanks for the head's-up IC. It looks like I have to make some custom standoffs for it anyway, so I will make them a bit beefier than the brass ones.
RC - Tapatalk
RobCee
Post by RobCee » Sun Mar 02, 2014 11:15 am
Samc99us - Yes the plate was cut on my SO2, with a feed rate of 300mm/min and a 0.1mm depth of cut. I had switched from the generic spindle to my Dremel as I bust the collet lock on the generic one. I used a speed of around 15000 rpm and plenty of WD40 as lubricant. The thing that made the biggest difference to the finish was blasting all the chips out with air at regular intervals. I picked up a multi-pack of keyboard air cleaner and have been using that for a while when working with aluminium, it really helps. On the down side, it blasts small chips of aluminium and WD40 all over the place, so there is plenty of cleanup required afterwards...
Post by WillAdams » Sun Mar 02, 2014 3:07 pm
Robcee,what alloy is that?
RobCee
Post by RobCee » Sun Mar 02, 2014 3:29 pm
It is 1050A, Will
RobCee
Post by RobCee » Tue Mar 04, 2014 7:24 pm
I finished making the spacers and mounted my Nema23 today.
Adapter in situ
21 Adapter In Situ.jpg (225.03 KiB) Viewed 3281 times
The spacing works well, just as planned; it lets me drive my spindle up right past the whole thing.
I did have a tricky time with the spacers though; I got impatient and tried power tapping one of them and ended up braking off the tap inside it - DOH!
There was not quite as much length on my M8 rod as anticipated either, so I had to change the heights on the upper spacers a bit too, but it works.
It's all a slippery slope here though - changing the motor means switching to upgraded cables for connection as I had to put a connector on it's shorter wires. That means reworking the other motors too, as it makes sense. Having the Z plates off to mess about with the connections meant I replaced my spindle mounts for my upgraded spindle. Looking at the various elements flexing now with the additional weight I may have to consider some reinforcement - my spindle may be a tough too heavy!
It all keeps me quiet though...
aroldfut
Post by aroldfut » Wed Mar 12, 2014 2:12 am
Your post and design has helped me decide the way to go with my Nema 23 Z-axis upgrade. In addition, I am adding a 1/2" 10tpi Acme screw. I already made a new Delrin block. Once it's attached and aligned to the Nema 23 I can move on to a solution for the clearance issue between the Makerslide and Z-Axis motor plate created by the thicker Acme screw. Again, well done!
