For a few years I have been following a thread on cnczone from Roman Black (Romanlini) for some DIY open source hall effect limit switches. So before I even ordered my SO2 kit, I was sure to order in the sensors I would need to use this idea on a SO2.
You can see Roman's original thread here: http://www.cnczone.com/forums/open-sour ... -easy.html
... and a the post on wiring here: http://www.cnczone.com/forums/open-sour ... post758009
... and a post on magnet tests here: http://www.cnczone.com/forums/open-sour ... post847057
So for the So2 (or SO1), I started thinking about how to mount these. Looking at the rails, it dawned on me that a T-Nut slot is readily available for every axis. I just needed a way to be able to mount the sensors using the slots, hopefully with some room for adjustment.
Here is what I have come up with. This will be machined out of 12.5 mm acrylic and should allow the sensors to use the existing TSlots. This photo shows the magnet sitting above the hall effect sensor body. It also hows an LED included in the body, but I expect that I will have to forego that feature as it will be quite tight just to get the sensor connected. The sensor mount is 32 mm x 10 mm.
Here you can easily see the magnet floating above the sensor and the yellow sensor in the slot below. The sensor is 4 mm x 3 mm x 1.5 mm. Soldering that in a way so the connections remain inside the sensor body (and get encased in epoxy) will be a challenge. Of course the soldering will be done first and then the soldered unit installed in the body.
Unlike Roman's version, the tight space will require the resistors to be mounted at the far end of the cable. I can add LEDs for each axis there as well.
While I am waiting for some 1/16" endmills to arrive, I have been trying to workout how to cut the needed reliefs in the backside. I think I can do it by cutting bolt holes in the stock, bolting the plexi to table , cutting the front pockets/reliefs, and then flipping the stock on the same bolt pattern. I am just worried that the machine position will not be in sync with the bolt spacing, but I do know how far apart the bolts are as I cut them using the machine. Guess I will have to try what I "think" will work and see.
Any advice appreciated.
Dennis
