1000x1000 projects
sectorix
1000x1000 projects
Post by sectorix » Tue Jul 29, 2014 8:11 pm
Hi,
Anyone has pictures or tips on a 1000mm on 1000mm build ? (using the Inventables extension kit)
Im trying to figure out what goes where and why.
Gadgetman!
Re: 1000x1000 projects
Post by Gadgetman! » Thu Jul 31, 2014 1:14 pm
Tips?
Yeah...
Check the build logs. There's a few 1000 x 1000 builds going through at the moment.
(Mine's one of them)
Generally, the difference is that you swap out the original Makerslides with 1000mm Makerslides, replace the belts and that's it.
Except that the Y-axis needs to be supported somehow. That's usually done with simple brackets on the inside where they won't interfere with the motor carriages.
Also, this thread really belongs in the 'General discussion/Discussion' forum, not in 'Design Ideas'.
Post by WillAdams » Thu Jul 31, 2014 1:25 pm
There are a couple of these machines under ``Square'' under: http://www.shapeoko.com/wiki/index.php/ ... mentations in the wiki.
as well as a section on the 1000x1000 Inventables upgrade: http://www.shapeoko.com/wiki/index.php/ ... es_Upgrade
and this was the size of the original scaled up machine used for stylus testing which Edward made which is also there.
Post by cvoinescu » Thu Jul 31, 2014 1:44 pm
Also, the eShapeoko comes in 1000mm x 1000mm as one of the standard options, and you can see how its frame, X-axis rail and X carriage are assembled in the assembly instructions.
polatype
Post by polatype » Sun Oct 05, 2014 2:48 pm
Can you link to some of the build logs as searching these forums is such a pain
Gadgetman!
Post by Gadgetman! » Sun Oct 05, 2014 3:51 pm
Mine:
http://www.shapeoko.com/forum/viewtopic.php?f=5&t=2025
http://www.shapeoko.com/forum/viewtopic.php?f=5&t=4281
http://www.shapeoko.com/forum/viewtopic.php?f=5&t=3756
Not certain about this one:
http://www.shapeoko.com/forum/viewtopic.php?f=5&t=1877
The first 3 were on the 'first page' of the build logs.
The 4th was on top of the second page of logs.
There may be a few more among them, and certainly a few older ones, too, but those are the ones that either state 1000x1000 or looks like it.
Frankly, there's almost as many ways of building a 1000x1000 machine as there are builders...
