Best Vacuum for CNC
Re: Best Vacuum for CNC
Post by twforeman » Fri Dec 05, 2014 8:25 pm
for_the_birds wrote:
twforeman wrote:I bought a Craftsman shop vac
Do you remember the model or HP?
I'll have to look when I get home, but a quick glance at the Sears web site shows that they have re-designed all their shop vacs again. Mine doesn't look like any of the ones listed.
LouisV
Post by LouisV » Fri Dec 05, 2014 8:36 pm
This is the vacuum that I'm currently using. It works well and isn't quite as loud as other shop vacs I've used. It has a pretty powerful motor rated at up to 5 peak HP with a 5 gallon capacity. I also like how it can hang on a wall.
for_the_birds
Post by for_the_birds » Fri Dec 05, 2014 10:58 pm
LouisV wrote:This is the vacuum that I'm currently using. It works well and isn't quite as loud as other shop vacs I've used. It has a pretty powerful motor rated at up to 5 peak HP with a 5 gallon capacity. I also like how it can hang on a wall.
That's a lot of power in a little machine. Does anyone use anything smaller than that? Space is somewhat limited under the shapeoko?
Post by WillAdams » Fri Dec 05, 2014 11:30 pm
Checked the little household vacuum I'm using: 1200 Watts, 9.5A.
tjshape
Post by tjshape » Sat Dec 06, 2014 1:21 am
I had contemplated this vac from Electrolux as well: http://www.amazon.com/gp/aw/d/B004Q0OLO ... 96-5435713. It's rated at 65dB and goes for about $160.
Shapeoko 2, ACME upgrade, Belt Drive Z-Axis upgrade, Dewalt DW660
oniontalker
Post by oniontalker » Sat Dec 06, 2014 1:45 am
I'd have a look at those cheap shopvacs also, a lot of them have the same motors in them, so it ends up just being the bucket size being the difference.
ShopVac + cyclone is a good place to be, of course you REALLY need to enclose that sucker and keep it cool, enough.
DanMc
Post by DanMc » Sat Dec 06, 2014 2:48 am
For the Fein vacs, look for the still available older models, for the Turbo II it's 9-55-13, for Turbo I 9-11-20. They just released new models which are way more expensive than the older ones. Still not cheap but they are great vacs
