VAC CONTROl
Re: VAC CONTROl
Post by cvoinescu » Sat Dec 20, 2014 11:15 am
What relay do you have?
Re: VAC CONTROl
Post by cvoinescu » Sat Dec 20, 2014 4:01 pm
That relay needs and active-high signal to enable it. GRBL outputs an active-low signal on the coolant control pin (A3). You can use the same inverter trick I posted not long ago (that was for the spindle), using both relays on that module; or you can just use the NC contact, because having the vacuum running is not a safety issue.
If you can't find my post with the schematic, let me know and I'll dig it up.
HPGreyling
Re: VAC CONTROl
Post by HPGreyling » Sat Dec 20, 2014 5:15 pm
Thanks again.
I do appreciate you assistance
The inverter trick you posted the last time was for me so I have it.
Just to be certain if I dont use the inverter trick do I connect A3 pin to channel 1 , ground to ground. What else am I missing
Re: VAC CONTROl
Post by cvoinescu » Sat Dec 20, 2014 5:34 pm
Sorry, I forgot it was for you, but the relay board looked very familiar. :)
You also need Arduino +5V to relay board VCC.
Gumboot
Re: VAC CONTROl
Post by Gumboot » Sat Jan 30, 2016 9:06 pm
I'm about to do the exact same thing. How did this work out for you?
I will be using the inverter add on found at http://www.shapeoko.com/forum/viewtopic.php?f=3&t=4630 as I want it to work only when the arduino is in use.
