Improved dust collector
Here's my latest dust collector. Tested and no dust escape. I like it.
The tube is mounted on the fix frame instead of the z assembly so it always have fix height from the materials being cut. Won't work though on 3D CNC which I never cut anyway.
https://www.youtube.com/watch?v=j-FNeZ_ ... e=youtu.be
Hardware: Shapeoko 2, Flashforge 3D Printer
http://www.thingiverse.com/francischie/about
Re: Improved dust collector
That's very nice.
What material is it made out of?
I use this hose: http://www.amazon.com/gp/product/B002YL ... UTF8&psc=1
The white are 3D printed PLA that I design.
That's really neat! What type of vacuum machine do you use? (it doesn't look like a typical shop vac)
Thanks, Caesar.
Thanks, Caesar.
It's Festool vacuum. I do DIY wood working before.
Thanks, I'll look it up.
Any close up pics of the mounting hardware to the frame?
Here's my improve version 2.
Improvement:
- Removed divider inside for more air passage and avoid blockage on on small debris.
- Added foam at the bottom for the best trap of all the dust.
- Acrylic top cover for more visible cutting.
- Vacuum can be set to the lowest suction and still no dust escape.
http://youtu.be/X7D7tmJIGMw
Now, I will really enjoy my Shapeoko without pesky dust and cleaning.
Update:
Files you need to build this one:
http://www.thingiverse.com/thing:696783
Improvement:
Update:
- Attachments
- 20150118_091241.jpg (314.71 KiB) Viewed 3353 times
- 20150118_091227.jpg (292.02 KiB) Viewed 3353 times
- 20150118_091220.jpg (306.71 KiB) Viewed 3353 times
Would you be willing to publish your CAD files so that I could customize them for my setup? If not, I appreciate the pictures and plan to use them for inspiration.FrancisChie wrote:Here's my improve version 2.
Improvement:
Fl0yd
Love the design and thanks for the detailed pictures. Yes...CAD files please!!!
