Unofficial Poll: Shapeoko 3 Work areas
The Shapeoko work area I need is
16" x 16" / 425mm x 425mm (stock)
8
6%
32"W x 16" / 850mm x 425mm
10
8%
16" x 32" / 425mm x 850mm
6
5%
48"W x 16" / 1075mm x 425mm
14
11%
32" x 32" / 850mm x 850mm
14
11%
48"W x 48" / 1075mm x 1075mm (half sheet of plywood)
43
32%
48"W x 64" / 1075mm x 1500mm
4
3%
48"W x 80" / 1075mm x 1925mm
2
2%
48"W x 96" / 1075mm x 2350mm (full sheet of plywood)
26
20%
Other --- please specify in comments
6
5%
Total votes: 133
Post by WillAdams » Tue Mar 10, 2015 2:46 am
This is an Unofficial effort at marketing research.
No guarantees, no promises, just a chance to share preferences /wishes and to comment.
In particular, is there some Metric standard for sheet goods which should be accommodated?
Re: Unofficial Poll: Shapeoko 3 Work areas
Post by WillAdams » Tue Mar 10, 2015 2:58 am
Darn. I suspect I should've included 48x32 rather than 48x64.
Brian Stone
Post by Brian Stone » Tue Mar 10, 2015 3:14 am
WillAdams wrote:Darn. I suspect I should've included 48x32 rather than 48x64.
48 x 32 is closer to my needs. I want to expand to fit comfortably on a standard workbench, typically 30 to 36 inches deep.
Shapeoko 2 #7353
LTEPM
Post by LTEPM » Tue Mar 10, 2015 4:26 am
Baltic Birch ply usually comes in sheets 60"x60", not sure how that relates to metric conversion.
Woodworker
Post by Woodworker » Tue Mar 10, 2015 5:25 am
1800x1000 as that is the current lengths that makerslide comes in and accommodates 48" x 24" or 1/4 sheet of plywood. In that you don't have to cut the makerslide to build a machine to cover that area. I believe it will also cover a 1/2 sheet of Baltic birch. What size is sheet goods in countries other than the U.S. ?
Gadgetman!
Post by Gadgetman! » Tue Mar 10, 2015 6:21 am
@LTPM, 60" is 1524mm.
(1" = 25.4mm)
CastIrony
Post by CastIrony » Tue Mar 10, 2015 8:30 am
My 1950s single car detached garage isn't big enough for a giant full-sheet machine, and even 1m x 1m would be pushing it.
Fortunately, the stuff I was planning to make would have just barely fit on the Shapeoko 2, so the extra 4" in each direction on the stock Shapeoko 3 is plenty for me.
RobCee
Post by RobCee » Tue Mar 10, 2015 8:48 am
Typical metric plywood sheets are described as 2440mm x 1220mm which is pretty much the rounded figures for an 8' x 4' sheet.
In other words, they are the same standard sizes.
Post by WillAdams » Tue Mar 10, 2015 10:39 am
Darn mixing units. I knew I should'nt've just added...
The metric sizes are short beyond 16"
48" == 1219.2mm
96" == 2438.4mm
Please round off based on that.
Post by cvoinescu » Tue Mar 10, 2015 10:41 am
So far we know:
US: a sheet is 8 ft by 4 ft, or 2438 mm by 1219 mm
UK: a sheet is 2440 mm by 1220 mm, so essentially the same; quarter sheets (1220 mm by 606 mm) are available in DIY stores, and also an in-between size of 1829 mm by 607 mm.
Can someone in the Continental Europe tell us what sheet sizes are common there? For instance, I seem to find 2800 mm by 2070 mm sheets of MDF and 2500 mm by 1250 mm plywood in German stores, but I don't know whether that's typical.
