Treatments for the Wasteboard?
Okay, at least one person has lacquered their Wasteboard — other options?
How ’bout applying the same laminate as is used on countertops?
m.wikihow.com/Put-Laminate-on-a-Counter-Top
Re: Treatments for the Wasteboard?
I chose polyurethane. Creates a thicker and more durable coat. Also it's fairly critical to seal the edges of MDF.WillAdams wrote:Okay, at least one person has lacquered their Wasteboard — other options?
Since the SO3 waste board isn't really a waste board but a structural element, I don't want to chew my waste board up. I don't plan to put any thing on my sacrificial waste board.
Any thoughts on attaching sac-waste-boards to the SO3 structural waste board?
SVEMakerSpaces
SVEMakerSpaces
I've been hoeing that row over in this thread: http://www.shapeoko.com/forum/viewtopic.php?f=35&t=6045woodworkerbob wrote:Any thoughts on attaching sac-waste-boards to the SO3 structural waste board?
On my 3rd design iteration of it, and think that this last variation should work out well --- guess I should spray lacquer or polyurethane on my MDF before I get too much further along.
I found this stuff, 1/2" x 4' x 4' Reversible Prefinished Panel, at my local menards and I think I'm going to use it. https://www.menards.com/main/building-m ... -13335.htm
It's available in different pre cut sizes and finishes and is reasonably affordable. The piece I mentioned about is $16
I will probably use a 1 1/2# cut of de waxed shellac. The thinner cut of shellac will be absorbed into the material. Easy to repair and will still adhere to double sided tape. You can build it up to the level of finish you want. Try to avoid water based finishes, it will raise the grain of the machine board.woodworkerbob wrote:You will need to laminate both sides to minimize wood movementWillAdams wrote:Okay, at least one person has lacquered their Wasteboard — other options?
I will make a 3/4" waste board with t-slots routed in MDF and likely thru-bolt to the machine baseboard.
Still working thru some issues, hope to get the first cut by end of next week.
I'm sure it varies by state and country, but I've found a lot of perfectly good "wasteboards" being thrown away in the garbage every week. Sometimes I see stacks of them. Old bookshelves, etc.
I fished the materials for the torsion box bed for my SO1 out of a neighbor’s trash. Worked great, and suited my budget at the time.
After the work I am doing to my wasteboard, I think I sill definitely seal it from the lovely Western Washington humidity.
Here is half of my new 3/4" MDF wasteboard. I only planned on using 100 threaded inserts, but I got carried away a bit, and am going to end up using 210. Whoops.
I only need to countersink four of the fastener holes, since all of the other holes cannot be touched by the cutters, and it is easier for me to just get longer screws. I used my portable table saw to cut the relief for the gantry to move above it, and after rough cutting the pieces, I used a flush cut bit on my router to trim them to match. Holes were done by mating the two original wasteboard halves together with the relief pockets facing each other. The two original wasteboards were clamped to a new half and then I drilled through the new wasteboard using the original wasteboards as a drill guide. Crude, but I don't have a drill press. I did it the same for the other half.
I reassembled my Shapeoko with the original wasteboards, and I am in the process of milling the rest of the pockets for the threaded inserts. It is definitely a learning experience.
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
