Custom ShapeOko Design
northbear
Post by northbear » Mon Aug 13, 2012 7:29 pm
** edited 8/15/2012 --- I re-read this and decided to remove my many words ***
Below are several pictures.
I welcome any comments or questions! Hopefully someone will find this of use and thanks again for all those who have helped me get this far!
1 iso.PNG (218.91 KiB) Viewed 3663 times
2 iso.PNG (154.57 KiB) Viewed 3663 times
rear iso.PNG (115.46 KiB) Viewed 3663 times
My buildlog is here
northbear
Re: Custom ShapeOko Design
Post by northbear » Mon Aug 13, 2012 7:31 pm
A couple more pictures
sec veiw iso.jpg (118.02 KiB) Viewed 3661 times
x gantry iso front.PNG (64.38 KiB) Viewed 3661 times
x gantry iso rear.PNG (59.68 KiB) Viewed 3661 times
My buildlog is here
willo
Post by willo » Mon Oct 01, 2012 3:39 am
If you're going to beef up the machine that much, lose the direct drive to the Z motor.
Add a belt drive to the Z axis and use at least a 2:1 ratio. You'll increase the torque for the Z axis.
If you raise the work surface, you could even attach a piece of extruded aluminum across the bottom of the Y plates for even greater stiffness.
Just some thoughts. You'll also find that the drag chain won't bend as severely as in the rendering. I attached mind to the top of my Y motor mount.
northbear
Post by northbear » Mon Oct 01, 2012 9:31 pm
Willo
Thanks for your comments!
I wasn't thinking I would need to increase the torque for the z axis as it is a screw drive and so should have plenty of torque. That being said I was going to use a nema 23 motor to keep all the motors the same which would add more torque anyways.
I don't believe the bend on the drag chain should be a problem as long as I pick a drag chain with the correct bend radius.
For example the below two drag chains are the same ID and OD but one has a radius of 38mm while the other has a radius of 18mm
http://www.ebay.com/itm/Cable-drag-chai ... 3a712c7cbb
http://www.ebay.com/itm/Cable-Drag-Chai ... 20ca8dcd44
The bend (overall top most point to bottom) should be the outside height plus the bend radius
My buildlog is here
loopingz
Post by loopingz » Tue Oct 02, 2012 8:41 am
So do you recommend high or low bend radius?
daveczrn
Post by daveczrn » Tue Oct 02, 2012 9:36 am
the smaller radius will allow it to fit in smaller area, i would go with that one.
