Completed My 3D Printed PLA SO3 Drag Chain Brackets
madhatter
Re: Completed My 3D Printed PLA SO3 Drag Chain Brackets
Post by madhatter » Wed Sep 23, 2015 6:19 pm
Looks nice. It's good to see that they worked for you.
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
doxie
Post by doxie » Wed Sep 30, 2015 5:47 pm
Hello! I think this my first post. Whooo.
I just made my Shapeoko 3, and I'd like to print out your mountain brackets for the drag chain. I did bracket 2 and the holes for the drag chain are a little off. Could I possibly get a copy of an openSCAD or some such format so that I can move things around? I'm using freeCAD, and it is really awkward to start from a stl file in there. Unless I'm simply ignorant, I'm new to the software.
Thanks! Drag chains are nifty.
Doxie
madhatter
Post by madhatter » Wed Sep 30, 2015 11:42 pm
Give me a list (in preferential order) of the formats you'd like the brackets in and I'll see what I can do. I am using SolidWorks 2014, so you can see what formats it can save in and see what matches up with freeCAD.
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
doxie
Post by doxie » Fri Oct 02, 2015 2:27 pm
Sweet!
I think the most preferential format will be a STEP file. At least, I loaded a sample of that into freeCAD and it is editable. The formats that are common between the programs are as follows:
STEP
IGES
DXS
VRML
Thanks again,
Doxie
sakumar
Post by sakumar » Fri Oct 02, 2015 3:25 pm
http://imgur.com/zDnkxBZ
Hi, I have the same problem as doxie -- my Drag chain end bracket holes don't match. I use Autodesk Fusion 360 which takes STEP files. Can you make those available? Thanks!
madhatter
Post by madhatter » Sat Oct 03, 2015 4:50 am
Okay, I am lazy (but only with certain things) so here is a copy-pasta if the link I updated in my first post:
NEW EDIT as of 02OCT15: Here are the STL, IGS, STEP 203 and 3DXML files if anyone wants to take them out for a spin.
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
doxie
Post by doxie » Sat Oct 03, 2015 7:36 pm
Sweet! Much obliged.
Thank you,
Doxie
sakumar
Post by sakumar » Sat Oct 03, 2015 9:31 pm
madhatter wrote:Okay, I am lazy (but only with certain things) so here is a copy-pasta if the link I updated in my first post:
Thank you! The STEP files can be edited using Autodesk Fusion 360, so I can now customize it the Drag chain I bought.
sakumar
Post by sakumar » Sun Oct 04, 2015 5:46 am
Hi Doxie,
You had a PM question about AutoDesk Fusion 360 -- I couldn't reply because apparently I haven't earned that privilege on this forum yet :roll: . Anyway, to delete a feature, click on it till it is highlighted in blue, right click and select delete.
doxie
Post by doxie » Sun Oct 04, 2015 1:15 pm
Thanks! I had to figure out the entire sketch thing and now it is all good. I'm printing the parts out as I write. We live in a strange world.
