Construction Ideas
SmokyRick
Construction Ideas
Post by SmokyRick » Sun Aug 30, 2015 6:57 pm
Has anyone thought of using this combination of things to make a ShapeOko- like machine? This just really captures my imagination.
Start with this type of linear shafting rail.
Add round gear racks.
And use open style pillow blocks for attaching the rest.
I just thought this would make a reasonable machine without using belts that stretch.
Comments?
CastIrony
Re: Construction Ideas
Post by CastIrony » Sun Aug 30, 2015 7:04 pm
AFAIK the stretched belts help avoid backlash, so you'd have to come up with a solution for that.
Post by WillAdams » Sun Aug 30, 2015 7:13 pm
Gonna be expensive.
Lots of different CNC designs out there and no end of discussion about them at sites such as CNC Zone.
Also, once the belts are tensioned, they tend to stay the same size.
orangezero
Post by orangezero » Wed Sep 09, 2015 5:36 pm
http://www.mcmaster.com/#99030a703/=yv5z0c 6ft of acme rod 3/8in with 1/2in per rotation. I don't understand why more people aren't using this at under $17 for a six foot piece. You wouldn't want to do six ft lengths due to whipping, but a 2-4ft section would probably work just fine. The cost is in the nuts, but those can be "made" in several ways that don't involve purchasing $30 nuts. 3/8in center hole bearings are not hard to find. The only issue I've had is that finding 3/8in gt2 pulleys or couplers is a bit more of a pain, if anyone has any links.
The cost of steel v-wheels is also coming down a bit more as well. Around $3 a wheel shipped from the US. The issue still remains some decent way to run them without ruining your budget. I'm really surprised no one has made a rail (via kickstarter, etc) which integrates a steel channel in some way.
