Good Job, Neppo1345!
Thanks Neppo1345, you have a good design there. How many screws did you use to attach to the plate? I put three holes for M5 tap on each. Was going to use four, but spacing didn't work out right. Attached is the Fusion 360 file for my variation of your design. Eager to hear how it works out if anyone uses it.Neppo1345 wrote:HDVideo, I like that take on it!![]()
I thought about extending mine down past the mount as well, but the 1/4 inch plate I had on hand wasn't long enough.
I cut my LH plate cut Wednesday. Didn't make any mistakes with the CAM this time, and played around with some new feeds and speeds that left a very nice surface finish.
Currently have the Z axis torn apart all over my bench with the hole locations marked out; got too tired the other night and had to call it quits (didn't want to make another rushed/tired mistake like I did with my CAM on the RH plate).
Planning on finishing it up this weekend...if it works I'll post up the DXFs.
