Tensioning the machine...
Max Metz
Post by Max Metz » Thu Sep 06, 2012 3:49 pm
I assembled the X and Y axis today, as one does up the bolts to secure the Makerslide to the end and motor plates the tension is critical if everything is to stay square. Over tighten just one bolt and the Makerslide twists in the small tolerance between hole and bolt, I noticed this earlier when assembling the x axis, ideally a small tension wrench would make things a lot easier.
The inexpensive way I did it was to fit spring washers between two flat washers to all 8 bolts on the x and y axis, tightening each until the spring washer just closed, then I tightened the bolts diagonally 1/8th of a turn on each axis until the machine began to twist - then I backed each bolt a little. This squared the machine without any twist.
These where taken with my phone camera. this first shot is of the top right x axis showing the spring washer between two flat washers.
This second image is of the front right showing the same washer arrangement.
I hope this helps someone else. :D
jrsteensen
Re: Tensioning the machine...
Post by jrsteensen » Thu Sep 06, 2012 3:57 pm
Good trick!
Pseudo
Post by Pseudo » Fri Sep 07, 2012 1:57 am
That's really useful advice; I was struggling with keeping my shapeoko square today and was about to ask the forum for advice but I think this is the answer, thanks :)
Max Metz
Post by Max Metz » Fri Sep 07, 2012 2:11 pm
Thanks jrsteensen and Pseudo. :D
iconeo
Post by iconeo » Tue Sep 11, 2012 11:37 pm
Can these be found at home depot or do they need to be ordered?
Sent from my EVO using Tapatalk 2
RSWeaverAz
Post by RSWeaverAz » Wed Sep 12, 2012 8:49 am
If he's talking about a Lock Washer as below:
There are metric and USA types available at Home Depot.
I Launch Rockets
, aka High Tech Welfare for Engineers
Your tax dollars have to go somewhere ... right!
ShapeOko S/N 396
Max Metz
Post by Max Metz » Wed Sep 12, 2012 2:22 pm
Thanks RSWeaverAz, this is exactly what I meant iconeo. Enjoy the day. :D
