Enclosure talk
Gamble
Enclosure talk
Post by Gamble » Thu Feb 18, 2016 2:52 am
For those that have built an enclosure. Knowing what you know now, what would you do different ?
I plan on doing one with extruded aluminum. Should I make it at least an inch or two wider and and deeper? Or as tight as possible?
Thinking using Lexan on the sides but not sure how well it will block noise or if I should use mdf. Heavier and will keep noise down but can't see through it
CNC Plasma Table
Tig, Mig Welders
Shapeoko3
Defy
Re: Enclosure talk
Post by Defy » Thu Feb 18, 2016 3:26 am
I made mine out of mdf and it's pretty quite. I made it taller than needed but it works and it easy to get too.
Defy
Re: Enclosure talk
Post by Defy » Thu Feb 18, 2016 3:29 am
Posted wrong second pic. Tapatalk wouldn't let me fix it.
k5beason
Re: Enclosure talk
Post by k5beason » Thu Feb 18, 2016 7:46 am
Here is my design. Don't have any pictures on me but its about 90% built. Waiting on the remaining Plexi Glass to come in.
It is built out of S4S 1x2's. 3/4" MDF, 1/2" Plexiglass. Will have a rubber seal around the door. There is enough room for the full cutting area without the Dust Shoe (extends past the shapeoko frame).
If I've calculated things right the Door should open and extend to a point to allow full access to the shapeoko and also push to create a tight seal when closed.
xfredericox
Re: Enclosure talk
Post by xfredericox » Thu Feb 18, 2016 11:53 am
http://www.manmademayhem.com
trevor
Re: Enclosure talk
Post by trevor » Thu Feb 18, 2016 6:34 pm
Heres mine
its nothing fancy. made it from 1/2 mdf and its essentially just a box inside a box with a 1 inch gap between them. I also used insulation to help with the noise.
i have since built a cart for it to be on so i can roll it around my shop.
But if i could do it differently...i wish i would have done it sooner!
Gamble
Re: Enclosure talk
Post by Gamble » Thu Feb 18, 2016 8:58 pm
nice. what size drag chains are you guys using?
CNC Plasma Table
Tig, Mig Welders
Shapeoko3
k5beason
Re: Enclosure talk
Post by k5beason » Sat Feb 20, 2016 10:36 pm
Here is everything test fit in place.
3D printer on slides below next to the enclosure for the shop vac
