Enclosure talk
Enclosure talk
For those that have built an enclosure. Knowing what you know now, what would you do different ?
I plan on doing one with extruded aluminum. Should I make it at least an inch or two wider and and deeper? Or as tight as possible?
Thinking using Lexan on the sides but not sure how well it will block noise or if I should use mdf. Heavier and will keep noise down but can't see through it
CNC Plasma Table
Tig, Mig Welders
Shapeoko3
Tig, Mig Welders
Shapeoko3
Re: Enclosure talk
I made mine out of mdf and it's pretty quite. I made it taller than needed but it works and it easy to get too.
Re: Enclosure talk
Posted wrong second pic. Tapatalk wouldn't let me fix it.
Re: Enclosure talk
Here is my design. Don't have any pictures on me but its about 90% built. Waiting on the remaining Plexi Glass to come in.
It is built out of S4S 1x2's. 3/4" MDF, 1/2" Plexiglass. Will have a rubber seal around the door. There is enough room for the full cutting area without the Dust Shoe (extends past the shapeoko frame).
If I've calculated things right the Door should open and extend to a point to allow full access to the shapeoko and also push to create a tight seal when closed.
Re: Enclosure talk
http://www.manmademayhem.com
Re: Enclosure talk
Heres mine
its nothing fancy. made it from 1/2 mdf and its essentially just a box inside a box with a 1 inch gap between them. I also used insulation to help with the noise.
i have since built a cart for it to be on so i can roll it around my shop.
But if i could do it differently...i wish i would have done it sooner!
Re: Enclosure talk
nice. what size drag chains are you guys using?
CNC Plasma Table
Tig, Mig Welders
Shapeoko3
Tig, Mig Welders
Shapeoko3
Re: Enclosure talk
Here is everything test fit in place.
3D printer on slides below next to the enclosure for the shop vac
