4 Axis mod ?
PsyKo
Re: 4 Axis mod ?
Post by PsyKo » Mon Feb 11, 2013 9:51 am
Hello,
damagi wrote:Any Updates on this?
I'm currently gathering the required parts. I already have the shaft mounting plates (http://www.damencnc.com/en/components/m ... arings/165)
I'm still waiting for the actual shaft, and have to decide of the driving method (either belt, gears or worm screw). The chuck will probably be a 3 jaw lathe chuck.
Before jumping in the metal cutting, I'll probably do a wooden prototype, with cheap parts :
- home made chuck,
- simple cheap shaft (non rectified for now),
- home made milled gears,
It will be a standalone 4th axis, simply because now I don't have the required electronic to use it as a CN axis. Maybe I'll upgrade to tinyG sometimes, but I'd also like to be able to manually rotate it (using a keyboard or something).
Does anyone have a good link for a simple and cheap stepper motor driver ( Nema 17, the same as used on the Shapeoko) ?
But most of all, I lack time for doing it :)
Shapeoko #736
alpha
Re: 4 Axis mod ?
Post by alpha » Mon Feb 11, 2013 10:04 pm
PsyKo wrote: Does anyone have a good link for a simple and cheap stepper motor driver ( Nema 17, the same as used on the Shapeoko) ?
I got me some of these on Black Friday, I just connected it to a breadboard yesterday and used an Arduino to and some pules to drive it... there is a little cheaper low current version - but I wanted something i can run without heat sinks...
The DRV8825 stepper motor driver carrier is a breakout board for TI’s DRV8825 microstepping bipolar stepper motor driver:
http://www.pololu.com/catalog/product/2133
