SO3 Extrusion Support Brackets
madhatter
Post by madhatter » Sat Feb 17, 2018 8:11 pm
In this thread I mentioned brackets for the extrusions that have the same hole pattern as 1-2-3 blocks so the rails can be raised for thicker materials. Here are some pics of what I Was talking about. The dimensions are pretty much made up with exception of the 1-2-3 block hole spacing and extrusion fastener hole dimensions. It was mainly to get the idea out and get some constructive feedback on the design. I am thinking about getting these made for my XXL (depending on cost) because I have some projects in mind that has thick raw stock, but I Am not going to be cutting all the way through it (so the cantilevered forces on the spindle carriage would not be an issue). For instance, cutting a 3/4" - 1" deep relief image in a 4" thick mantelpiece. I am not going to cut through it, but I need the clearance.
SO3 Brkt001.JPG (35.01 KiB) Viewed 726 times
SO3 Brkt002.JPG (34.87 KiB) Viewed 726 times
SO3 Brkt003.JPG (51.29 KiB) Viewed 726 times
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
madhatter
Re: SO3 Extrusion Support Brackets
Post by madhatter » Sat Feb 17, 2018 8:13 pm
SO3 Brkt004.JPG (52.96 KiB) Viewed 724 times
SO3 Brkt005.JPG (44.11 KiB) Viewed 724 times
SO3 Brkt006.JPG (57.04 KiB) Viewed 724 times
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
madhatter
Post by madhatter » Sat Feb 17, 2018 8:14 pm
SO3 Brkt007.JPG (37.25 KiB) Viewed 723 times
SO3 Brkt008.JPG (45.36 KiB) Viewed 723 times
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
cgallery
Post by cgallery » Sat Feb 17, 2018 8:17 pm
How would you keep things square/parallel when moving the machine?
madhatter
Post by madhatter » Sat Feb 17, 2018 8:24 pm
My plan is to use the Misumi T-slot plates mounted to a box beam base made of 3/4" - 1" MDF. That will give me one straight edge to start with, and with a good square I would like to think that I can get the other dimension square.
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
