Zeroing issue
woodhobby11
Zeroing issue
Post by woodhobby11 » Fri Apr 05, 2019 5:28 pm
So I have this logo that I want to cut out and fill with epoxy. My idea is to design the logo and save all the toolpaths. I first cut out the background and fill it with epoxy. After a couple days I want to set it back up into the CNC and cut out the lettering in the epoxy. But I am having a problem trying to reload the exact xy values as the first time. I dont know if the CNC can even do this but if anyone has any idea how i can go about doing this or even tell me if its even possible that would be great.
Re: Zeroing issue
Post by WillAdams » Fri Apr 05, 2019 5:43 pm
The machine should save the offsets and reuse them if you have homing switches.
If not, you could machine a pocket which just admits the endmill, set that to be zero, then start up the machine with the endmill in said pocket.
woodhobby11
Re: Zeroing issue
Post by woodhobby11 » Mon Apr 15, 2019 12:15 am
WillAdams wrote:The machine should save the offsets and reuse them if you have homing switches.
The pocket for zeroing worked perfectly. Thank you so much for the idea.
