Suggestions for CNC work bench/table
nfortosis
Post by nfortosis » Wed Nov 21, 2012 10:57 pm
I am slowing aquiring all the parts I need to expand my shapeoko to roughly 900mm x 500mm. I just realized that size is too big to fit on my current workbench with the rest of my tools, which means I need to build a new table for my shapeoko.
My current work bench I inherited and is made out of an old hollow core door with metal frame for legs and lower shelf. The surface is nice, but the legs are a little wobbly.
What kind of materials have you guys used for your work surfaces? Any cheap suggestions?
Shapeoko #165: 1m X 1m, Double X, Dual Y motors, Acme upgrade, DW660
jsbannis
Re: Suggestions for CNC work bench/table
Post by jsbannis » Wed Nov 21, 2012 11:06 pm
2x4 lumber for legs and support structure, 3/4" chipboard top with 1/4 plywood or MDF on top of that for a more smooth surface. Anchor it into the floor or wall and it won't go anywhere. Having the MDF on top of chipboard would let you use it as a spoil board and swap it when it gets chewed up.
shapeoko #0057
Post by edwardrford » Fri Nov 23, 2012 1:37 pm
I'm thinking about getting one of these from Harbor Freight: http://www.harborfreight.com/adjustable ... 46725.html
Worktop looks like it'll hold a standard Shapeoko. Not sure how stiff it'll be, but for $26 I want to find out.
Post by edwardrford » Sun Nov 25, 2012 6:48 pm
I ended up picking one of these up on Friday. Ends up that a standard shapeoko fits *perfectly* on the top. I checked with the store and they confirmed this item ships for $7 flat rate shipping, so even delivered it's still less than $35. Which, IMO is a pretty good deal.
I have some ideas regarding what can be done with this sort of platform, but I don't want to hijack this thread. I'll start something new and post an edit to this.
UPDATE: Here's the new post: http://shapeoko.com/forum/viewtopic.php?f=11&t=1002
madmike88
Post by madmike88 » Sun Nov 25, 2012 9:20 pm
Edward, I'm looking forward to your thread and pictures with the shapeoko mounted. I have just assembled the shapeoko and now need something to mount it on.
nfortosis
Post by nfortosis » Mon Nov 26, 2012 8:32 pm
Edward's idea looks great, and if I were going to stick with a standard size shapeoko I would probably buy one, but I am interested in what people with expanded shapeokos have used. Are you guys just using your preexisting workspace or have any of you built/designed a bench with your shapeoko in mind?
Post by Improbable Construct » Mon Nov 26, 2012 9:01 pm
I built a table for mine using 1" box steel. I didn't put any cross bracing in it and it moves a bit but the table and machine are bolted togeather so it no a big deal if it sways a bit with big rapid moves.
You can sort of see it on my wiki page:
http://www.shapeoko.com/wiki/index.php/ ... _Construct
There are also some shots of it in this thread:
http://www.shapeoko.com/forum/viewtopic.php?f=11&t=643
I will try to put up some better pictures if I can figure out how to upload them from my iPad. Right now they are to big.
