I have a question about Linear Rails
Dallas
Post by Dallas » Fri Sep 06, 2019 7:28 pm
I'm upgrading my z-axis -- a poor man's version of the HDZ. I'll share the details in a couple of weeks (assuming it works. :lol: )...
I have a question for the community. I bought really, really cheap MGN12 linear rails from Banggood: https://www.banggood.com/Machifit-MGN12 ... rehouse=CN
I got the 250mm long ones. The first set arrived and I notices a slight bend in the rail. If you put the rails back to back, there's maybe a 1-2mm gap at the ends; they curve away from each other.
These are pretty beefy pieces of steel so I don't think they got bent during transport. I figured that went I socked them down to the baseplate, it would take the bend out so no big deal.
All by themselves, the trucks glide on the rails like a hot iron on a frozen lake (even with the bend). When I tighten down my cross plate to the trucks, the trucks start to bind. Now the cross plate is flat so I'm not buckling the trucks as far as I know. If I loosen the screws ever so slightly, I can get the trucks to glide easily again.
I wondered if the bend was causing the issue. A dead-flat truck wouldn't want to glide on a curved rail. So I bought another set from Banggood. (They are cheap; it was a low risk investment.) The second set arrived yesterday but they also are slightly curved; just like the first set. I haven't had time to install them to see if the tight-mounting-screws-cause-binding issue resurfaces.
I'm not complaining about the quality of the linear rails. You get what you pay for.
My question is: Are linear rails supposed to be 'pre-sprung'. Perhaps that bend is normal... Is there a reason that the trucks would bind when something is mounted to them very tight?
I have no experience with linear rails and would love to hear from those who do.
(As an aside: I bought a dirt cheap ballscrew off eBay and was pleasantly surprised with the quality. It will be more than adequate for my needs. So dirt cheap isn't always that bad.)
Phil
Zman
Re: I have a question about Linear Rails
Post by Zman » Fri Jun 18, 2021 11:12 pm
Unfortunately, we get what we paid for. My XXLPro came with some major box damage. I borrowed some "certified" straight edges, squares and calipers to test everything out. The X-Axis rail box was damaged, checked all the rails out anyway. None were off more than .0005 thousands. The X was perfect.
That said, 2mm over in that short distance could cause an issue. Not being there, this is my best guess
