6 High Speed Milling Cutters for $3 ?
sell your stuff here
Forum rules
janapriya
Post by janapriya » Fri Mar 07, 2014 11:39 pm
I came across this from a deal site, could this be used with Shapeoko? Please note I have no connection with meritline.com. Bought some stuff from them that's all :D
6 in 1 High Speed Steel Milling Cutters, Rotary File Set (0046999-001) for $2.99 [meritline.com] + Free Shipping
Coupon Code: MLCS07BN
http://www.meritline.com/showproduct.as ... y-file-set
Re: 6 High Speed Milling Cutters for $3 ?
Post by Improbable Construct » Sat Mar 08, 2014 1:23 am
I have a feeling that the results you would get from those cutters would be undesirable, but hey, for $3 why not give it a try.
MeanderBolt
Post by MeanderBolt » Sat Mar 08, 2014 2:51 pm
These look similar to the Dremel bits you can buy. Whilst not a pro yet at the whole Shapeoko thing, I have some of those and when you look at how the mills are constructed and how sharp they are... I don't think that this is where you want to be. Check out the Drillman1 on eBay. He has excellent prices and the bits are really nice. I bought a nice start up selection. Now, to throw a disclaimer, this is still an early opinion though as I have only had time to use a couple. But others on the forum really like Drillman1's stuff, and it is on the recommended list of recommended recommendations.
Shapeoko 2 # 3569 - DW660
Build log
Post by Improbable Construct » Sat Mar 08, 2014 3:05 pm
The bits from Drillman1 are excellent.
I use them almost exclusively (I have a great v bit with a replaceable cutter from amana tool)
You cant go wrong with the 1/8" two flute end mill. Be sure to get the UP cutting bits NOT the down cutting ones.
janapriya
Post by janapriya » Sat Mar 08, 2014 4:43 pm
Thanks guys. I ordered these anyways since it is $3. Worst case I will use them with my Dremel.
Thanks for the pointer on recommended bits! He is already in my fav ebay seller list :-).
bluecamel
Post by bluecamel » Wed Apr 02, 2014 5:46 pm
Improbable Construct wrote:Be sure to get the UP cutting bits NOT the down cutting ones.
How is it worded on the auctions? I see references to center cut but nothing about up or down.
Shapeoko 2 ..::.. DW660 with 3d printed mounts, HDPE version of IC's dust shoe
Nigel K Tolley
Post by Nigel K Tolley » Thu Apr 03, 2014 1:08 pm
Just look at the photo.
If the twist is such that when spinning clockwise it pulls material out the hole, then that's the one you want.
bluecamel
Post by bluecamel » Thu Apr 03, 2014 1:30 pm
Nigel K Tolley wrote:Just look at the photo.
Well, that's just too simple. Thanks!
