Belt Drive NEMA 23 Z axis kit
sell your stuff here
Forum rules
Post by Improbable Construct » Thu Oct 09, 2014 7:02 pm
Edward and I have been working on a belt drive kit for the Z axis for quite awhile and it is finally done.
You can find it here:
http://shop.shapeoko.com/collections/fr ... z-axis-kit
It moves the Z axis motor back giving you more clearance for your spindle. It also features a 2:1 ratio so that you can turn up the speed on your Z axis.
EDIT: There will be a NEMA 17 version as well I am just waiting on the belts to get here! I expect them within a week.
crazeegeek
Re: Belt Drive NEMA 23 Z axis kit
Post by crazeegeek » Thu Oct 09, 2014 7:14 pm
I ordered mine already! Don't need it, but had to have it.
CastIrony
Post by CastIrony » Thu Oct 09, 2014 7:18 pm
Looks like it also has NEMA 17 holes?
Post by Improbable Construct » Thu Oct 09, 2014 7:38 pm
tbfleming
Post by tbfleming » Thu Oct 09, 2014 9:23 pm
Any videos of it running?
Post by Improbable Construct » Thu Oct 09, 2014 11:19 pm
tbfleming
Post by tbfleming » Fri Oct 10, 2014 1:28 am
Very nice.
calica
Post by calica » Sun Oct 12, 2014 6:37 am
Does it work with the acme screw upgrade?
CastIrony
Post by CastIrony » Sun Oct 12, 2014 7:18 am
calica wrote:Does it work with the acme screw upgrade?
It requires it.
AFK66
Post by AFK66 » Sun Oct 19, 2014 9:36 pm
My bearing sits lose in the new plate, it falls right out and has a decent amount of play. Did I receive a defective plate?
Shapeoko 2 - Acme Rod/Belt Drive, Nema 23 steppers, 300 Watt Spindle - other wise stock
Shapeoko 2 inspired custom build - 1500 X 1000mm, Routakit HD Z and X axis setup, Nema 23 276oz steppers, 800 Watt Spindle, Geck 540/ Soigeneris STDR-4C controlled.
