Belt Drive NEMA 23 Z axis kit
sell your stuff here
Forum rules
crazeegeek
Re: Belt Drive NEMA 23 Z axis kit
Post by crazeegeek » Sun Oct 19, 2014 10:11 pm
AFK66 wrote:My bearing sits lose in the new plate, it falls right out and has a decent amount of play. Did I receive a defective plate?
It is OK that the bearing sits loose in the plate, but the play should not be that much and it shouldn't be falling out once assembled.
If you are not already using it, take the 8mm shim washer from your original Acme upgrade kit. Remove the new plate and bearing, then drop the 8mm shim washer onto the Acme screw and reassemble. This should correct any play.
Also, don't forget to place a Z-Axis Shim Plate on both ends, I know I did and had to do it twice.
Post by Improbable Construct » Sun Oct 19, 2014 11:04 pm
The hole in the new plate is a loose fit. It's it's not a problem because the force on the bearing are into the plate and then the belt pulls the bearing tight. Having the loose fit really helps with the assembly.
LouisV
Post by LouisV » Mon Oct 20, 2014 12:27 am
That looks great! I know a lot of people are going to want that upgrade. I could have used it on my upgraded Shapeoko 2 when I still had it.
AFK66
Post by AFK66 » Mon Oct 20, 2014 1:30 am
Awesome I just wanted to make sure before I give it a try.
Shapeoko 2 - Acme Rod/Belt Drive, Nema 23 steppers, 300 Watt Spindle - other wise stock
Shapeoko 2 inspired custom build - 1500 X 1000mm, Routakit HD Z and X axis setup, Nema 23 276oz steppers, 800 Watt Spindle, Geck 540/ Soigeneris STDR-4C controlled.
Post by twforeman » Mon Oct 20, 2014 1:45 am
Looks great, I'll have to pick one up for when I re-jigger my Z axis!
LTMNO
Post by LTMNO » Tue Oct 21, 2014 1:30 pm
Very Cool! Thanks for posting... and selling.
lildave
Post by lildave » Tue Oct 21, 2014 3:53 pm
Post by Improbable Construct » Tue Oct 21, 2014 4:13 pm
lildave wrote:Image
Looks great!
How was the install?
Did everything go together as expected?
groguard
Post by groguard » Tue Oct 21, 2014 6:37 pm
The reason I decided to purchase one was to help with the clearance on my Z, so I could put my DW660 back together. Im using the Inventables aluminum mounts and the Z plate doesnt allow for full travel. From what it looks like it should clear no problem once I get this installed.
Build Log
lildave
Post by lildave » Tue Oct 21, 2014 7:46 pm
Piece of cake 15min install.
I can even reach the switch with no problem. A must for z intensive.
