New Release of PicEngrave Pro 5
sell your stuff here
Forum rules
picengravertoo
Post by picengravertoo » Sat Dec 13, 2014 12:20 pm
Hi everyone.
We have been in testing for quite some time now using our Shapeoko 2 to make our full featured Image to gcode program completely grbl 9g compatible. PicEngrave Pro 5 has been officially released.
PEP5 has Analog, TTL modulation and Variable Feed Rate Laser photo engraving options and I know this forum is not relative, but now also supports PWM gcode for the LazerBlade grbl. With PicEngrave a settable Variable "Feed Rate Change" can be added to each line of gcode for image shading enhancements. Sonny Jeon's (chamnit) 9g is the only grbl available that can run our X, Y, Z & F Raster gcode on each line without any issues. Thanks again Sonny for making this all possible!
Our "Feed Rate Change" option can also be used with Spindle photo engravings for reducing the chip load in deeper cutting areas and then speeds up in shallow cut areas. Anyone that makes Lithophanes knows that a smaller bit gives best detailed results, but the risk of bit breakage increases and a roughing pass is always needed first. With our "FRC" option, Lithophanes can be engraved in one pass with a smaller bit to save on the overall project time.
A full list of PEP5 features, upgrade offers and a Demo Download is available on our web site.
Thanks.
Jeff
Shapeoko 2 Laser Diode Engraver-Analog/TTL/PWM
PicEngrave Pro 6 Image to Gcode for grbl/Mach3 controllers-Spindle/Laser
PicLaser: Image to Gcode With Editor
PicSender: Streams grbl Raster/Vector Gcodes
https://www.picengrave.com
picengravertoo
Re: New Release of PicEngrave Pro 5
Post by picengravertoo » Wed Jan 14, 2015 6:43 pm
Thank you everyone for the overwhelming response and patronage for our new release of PicEngrave Pro 5. We are continually adding new features and for those that have already purchased PEP5, here is a download link to our latest update. http://www.picengrave.com/downloads/pep5setup.zip
Here are the features of our software programs used with our Award Winning Shapeoko Laser Diode photo engraver build that is on instructables.
http://www.instructables.com/id/Shapeok ... ster-Phot/
PicEngrave Pro 5 Features:
• Engrave Horizontal - Vertical - 45° Left - 45° Right
• 2x Horizontal and Vertical Resolution
• Engrave Elliptical Cut-out Shape
• Crop Image
• Customize Gcode with Pre-codes and Post-codes
• Engrave Image Edges
• Lithophane Setting
• Imperial or Metric
• Resize Images
• Add Text to Images
• Adjust Brightness, Contrast, and Gamma
• Change Axis Assignment Letters to Z,A,B or C
• Improved Image Centering in Material
• Save and Reload All Program Settings
• Imbed File Settings in Gcode for Future Reference
• Rotate Image
• Flip Image
• Offset X and Y Start Positions in Material
• Adjustable Pixel Resolution
• Imports 5 Image Types BMP - JPG - PNG - TIF - GIF
• Spindle On/Off Gcode Insertion
• Sharpen Images
• Grayscale Preview
• Print Edited Images
• Now Supports Laser Diode Engraving in Analog, TTL and PWM Modes
• Dither Images for TTL Engraving with 11 Different Algorithms
• Change Axis Letter Assignments
• Select Gcode File Comment Character
• Produce Variable Feed Rate Gcode for Engraving gray scale Images with a TTL only Controllers
• Unique to PicEngrave Software - Combine Laser Analog Control and Variable Feed Rate for Enhanced Laser Engravings
• Enable Extended Edging for High Speed CNC Laser Engravers
• Generates Rotary Gcode for Spindle and Laser Engraving
• New Rotary Code Format
• Improved support for International MS Windows Users -Version 5.0.0
• New User Interface
• GRBL Support for Rotary Spindle, Analog Laser, TTL Laser, and PWM Laser
• LazerBlade PWM Gcode Support
• Mach3 TTL M10/M11 Gcode Support
• Advanced Gray Curve Adjustment to Lighten Mid-Range Shades in an Image
• Backlash Compensation
• Auto calculation of engraving size based on Pixel Resolution used in the "Edit Image" Auxiliary Program
PicLaser Lite Features: Standard Version. http://www.picengrave.com/downloads/PLLSVsetup.zip
J-Tech's Version. http://www.picengrave.com/downloads/Jte ... Tsetup.zip
• Supports Laser Diode Engraving
• Analog, TTL, and PWM Modes
• Works with Windows language versions that use commas or periods as decimal separators.
Our J-Tech version of PicLaser Lite has the same features and controller support as our standard version, but we added 3D printer PWM controller support for those users as well.
http://jtechphotonics.com/?product=picl ... sw-license
PicEdit Lite Features: This is the Lite version of our image editor that's included in PicEngrave Pro 5. It will save to the .bmp image format that will load in our PicLaser Lite program. With the Dithering options included, it can be a very inexpensive solution for CO2 laser engravers also. http://www.picengrave.com/downloads/PELsetup.zip
• Resize Images
• Sharpen Images
• Grayscale Preview
PicSender Features: http://www.picengrave.com/downloads/PicSendersetup.zip
• Streams fast changing image Gcode files to GRBL.
• Supports grbl 8 & 9 , Andy's LaserMode PWM grbl and EmBlaser PWM grbl (aka LazerBlade)
• Displays position feedback responses from GRBL.
• Select jog modes - Absolute or Incremental.
• Select jog move values.
• Manual keyboard jog.
• Sets/resets G54 offset values.
• Loads and seamlessly streams Gcode files of up to 10 million lines in length.
• Display and set GRBL setup values.
• Manual control of spindle/laser output signal.
• Manual command option
• Detects and reports Gcode format errors.
• Elapsed run time display.
• Run time progress indicator.
• Simple and easy-to-use controls.
• Use with lasers or rotary spindles.
• Easy batch editing of GRBL settings.
• Save settings to uniquely named files for later recall.
• Load previously saved setting files.
• Easily review all settings before uploading to GRBL.
• Send settings to GRBL one at a time, or all at the same time.
• Compare present and previous settings.
PicLaser 3D Features: If your Shapeoko has a 4 axis controller, then your spindle relief gcodes & laser gcodes can be combined together for the laser diode's focal point will follow the contours for shading your masterpieces. Works only with gcode generated from PicEngrave Pro 5 & PicLaser Lite. http://www.picengrave.com/downloads/Pic ... V1.0.0.zip
• Combines spindle relief gcode with analog laser gcode to shade toolpath profiles.
• *.txt, *.nc, *.ncc or *.tap CNC gcode files excepted for combining.
• A, B or C analog Laser gcode combined with X, Y and Z spindle relief gcode.
• Variable "Feed Rate Change" (F) will also be combined if present in the gcode.
• Comment character ignore option to ensure syncronization of the two gcodes.
• "_combined" automatically added to the original laser file name when saved.
• Uses your Default Text Editor to view files.
PicFRC Features: For our PicLaser lite customers that want's to add our Advanced " Feed Rate Change" laser diode image engraving enhancement feature that is in our PicEngrave Pro 5. It also has a file dividing option to precisely break up those very large raster files for Mach3 10,000,000 line limit to run them separately.
• Adds Variable Feed Rate for Enhanced Photo Laser Engravings.
• For use with Gcodes Generated with PicLaser Lite, running in Mach3, grbl 9g, and Andy's LaserMode PWM grbl.
• Set percentage based on Z,A,B, or C axis depths or S PWM Laser Power level commands from the full feed rate setting.
• Option to Create one full file or divide the file up into 5 individual files for a work around to Mach3 10,000,000 Gcode line limit.
• "_PicFRC_#" automatically added to the original file name when saved.
For our future customers, all our Pic Product downloads here can be testing first before your purchase. Please visit our web site and Wagner will greet you there. :D
http://www.picengrave.com/index.htm
Thanks again everyone.
Jeff
picengravertoo
Post by picengravertoo » Tue Feb 10, 2015 12:14 pm
Latest version updates available for download.
PicEngrave Pro 5 V5.0.09: http://www.picengrave.com/PicEngraver%2 ... 0Laser.htm
PicEdit Lite V1.0.03: http://www.picengrave.com/PicEdit%20Lite.htm
PicSender V2.0.05: http://www.picengrave.com/PicSender.htm
picengravertoo
April Promotion
Post by picengravertoo » Tue Apr 07, 2015 1:35 pm
April Promotion.
http://www.picengrave.com/PicLaser%20Lite.htm
Thanks.
Jeff
picengravertoo
Post by picengravertoo » Wed Jun 03, 2015 7:37 pm
