Shapeoko 2 ACME Upgrade Preorder
sell your stuff here
Forum rules
Post by Improbable Construct » Tue Aug 11, 2015 2:31 pm
I am putting together another batch of ACME screw kits for the Shapeoko 2.
They are available for preorder here:
http://improbableconstruct.com/products ... me-upgrade
Parts have been ordered and I expect to start shipping on or before September 9th 2015.
RaymondOverman
Re: Shapeoko 2 ACME Upgrade Preorder
Post by RaymondOverman » Tue Aug 11, 2015 5:51 pm
Done and done. Looking forward to getting these in. Just hold the belt drive kit and ship all at once if that saves you some coin since one is a pre-req for the other.
Thanks for putting them together!
SO2 / NEMA 23s / 5 axis SainSmart BOB and Drivers / DW660 Spindle / Rotary Axis / Spindle-Vac Relay / LimSW / Fender Wells / Drilled and Tapped 1"x8TPI Waste Board
samc99us
Post by samc99us » Tue Aug 11, 2015 6:50 pm
Any chance of moving to an anti-backlash nut solution, ala http://openbuildspartstore.com/anti-bac ... ead-screw/
Best,
Sam
Post by Improbable Construct » Tue Aug 11, 2015 7:33 pm
I have tried a variety of anti backlash nuts and other solutions.
They all work to some degree but the real problem is flex in the structure of the S2. The tiny bit of backlash that can be eliminated is nothing compared to the flex in the X and Z axis.
That being said, If you want to use the open builds anti backlash nut, buy one, send it to me and I will re-tap it for 3/8 ACME and send it back to you free of charge. The 8mm threaded rod actually makes a pretty good starter hole for the 3/8" ACME.
Arbies
Post by Arbies » Tue Aug 11, 2015 9:58 pm
RaymondOverman wrote:Done and done. Looking forward to getting these in. Just hold the belt drive kit and ship all at once if that saves you some coin since one is a pre-req for the other.
Took the words right out of my mouth. Both about being excited and holding shipping until both are available.
samc99us
Post by samc99us » Wed Aug 12, 2015 12:10 pm
Hmm. I know the anti-backlash nut made a difference in my z-axis on my basically stock SO2 z-axis setup (though the rest of the machine is stiffer). I've moved to a stiffer z-axis (basically a similar setup to what you were running on your classified machine, 8020 z-axis, 8x v-wheels etc.), so I am sure it will be even more noticeable without it. Does add a fair amount of friction to the system however.
Caesar S
Post by Caesar S » Thu Aug 13, 2015 9:49 pm
Can I order for a slightly longer length (16in) length?
Post by Improbable Construct » Thu Aug 13, 2015 10:16 pm
I can make custom length screws in either single or 4 start versions. PM or email me for more info.
Caesar S
Post by Caesar S » Sat Aug 15, 2015 4:36 pm
Improbable Construct wrote:I can make custom length screws in either single or 4 start versions. PM or email me for more info.
What is a 4 start version?
Thank you, Caesar.
Post by Improbable Construct » Sun Aug 16, 2015 12:53 am
It has 4 thread paths on the screw instead of just one. If you are running a high torque motor you can increase your speed x4 without spinning your motor faster and losing that torque.
