Azteeg G1 All-in-one CNC Controller
Forum rules
Re: Azteeg G1 All-in-one CNC Controller
I got mine today....
Off to wire it up.
Off to wire it up.
Well everything is wired up and tested. Works nicely as described. I had to read up on grbl at little to set up my 0.9degree/step motors but other than that it was a nice product.
I'm waiting on my heat shrink before I permanently set up my ShapeOko out in the garage. I'll send some pictures maybe early next week.
One thing that might be an issue but maybe it wont be is the top shield prevents the chips from getting exposed directly to the air. Now forced cooling through the side is still doable, as there is some room. But after doing my Hello World print it was noticeably warm.
All in all nice product
VeDub,
The design intent is to remove heat from the underside of the driver chip where its heat pad is. If you are using a heatsink it is advisable to place it at the bottom of the board. The board runs fine with 2Amps or less without a heatsink(gets to 65deg C). Get a heatsink with an adhesive or you can use the 2 holes to secure it. On the video on the link I used a copper bar I have lying around as heatsink bolted to the PCB. Try to avoid placing the heatsink on the top of the chip. Im trying to have a plate made that will attach to the bottom by screws so it will be easier to mount(heatsink + metal mount). I was planning to mount mine on the back plate of the shapeoko with a shroud or plastic enclosure.
When you start playing with it try using the 1/32 mstep + 0.9 motors just for kicks and see how it works for you. I have not tried it but should be interesting to see how it works out.
royco
royco
Azteeg G1-328P Vref?
Roy, what multiplier should we use for Vref when setting current limits? Or asked another way, what is the value of the current sense resistor? Is it the same as for the SureStepr (Current Limit = Vref x 2.5)?
The Shunt is 0.1 Ohm.
I limit = Vref x 2
I limit = Vref x 2
Just ordered mine - what is the lead time?
@jimmy - about a week. Thanks
On the website it says preorder, but it seems people are ordering them. Which is correct? How long until it it back in stock?
royco wrote:@jimmy - about a week. Thanks
So I should get it next week? My motors and stuff got here today and I'd love to hook it all up and test it out next week.
I just wanted to post that I got mine and it works great. I hooked it up and ran GRBL Controller 3.3.3 and it worked without adjusting anything. For some reason the Z axis was inverted so i reversed the wires. Ran the hello world with a sharpie and it worked first try. Thanks for making it.
Chris
Chris
