ACME screw upgrade for Shapeoko Z-Axis
sell your stuff here
Forum rules
Tom Smith
Re: ACME screw upgrade for Shapeoko Z-Axis
Post by Tom Smith » Sun May 05, 2013 7:40 pm
WillAdams wrote:Did you clamp the rod down before cutting?
I almost broke a hacksaw blade, then clamped the rod and finished the cut w/o further incident.
Yeah, the blade teeth were worn right off...I think it is more a matter of using a better hacksaw blade!
Anyhow, I need to get more cutoff wheels, and I think they'll do the trick.
_______________
ShapeOko1 191
danimal
Post by danimal » Mon May 06, 2013 7:41 am
Just jumpped on one. Hope they are still in stock. I went through about 40 different suppliers and with all the coordination and work it would take to make this kit and I realized it is a really a good deal. Cant wait until it gets here. Thanks IC
Shapeoko # 1458
jsbannis
Post by jsbannis » Wed May 08, 2013 11:10 pm
I used a dremel cuttoff on mine and worked well; only took a few minutes.
shapeoko #0057
Tom Smith
Post by Tom Smith » Thu May 09, 2013 12:02 am
jsbannis wrote: I used a dremel cuttoff on mine and worked well; only took a few minutes.
Yep, one of the fiberglass cutoff wheels did the job of cutting, then of edge smoothing :-)
Tom
_______________
ShapeOko1 191
Improbable Construct
Post by Improbable Construct » Fri May 24, 2013 1:47 am
Z axis upgrades are once again temporarily out of stock.
I hope to have them back in stock by the end of May.
Feel free to comment here or PM me if you would like to be notified when they are back in stock.
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
Post by Improbable Construct » Thu May 30, 2013 11:49 pm
ACME Z axis upgrades are back in stock!
You can find them here:
http://www.shapeoko.com/upgrades
Shapeoko 3 # 0003
Store:
Twitter:
whitecloud
Post by whitecloud » Wed Jul 10, 2013 1:09 am
Would you consider selling just the Delrin Nuts? I need two of them and am hesitant to invest in a tap that I might never use again.
Post by WillAdams » Wed Jul 10, 2013 1:14 am
Have you considered using metal nuts instead?
http://www.shapeoko.com/forum/viewtopic.php?f=11&t=751
Post by Improbable Construct » Wed Jul 10, 2013 3:15 am
Yes. I do sell just the Delrin nuts. I will send you a PM.
Shapeoko 3 # 0003
Store:
Twitter:
Post by Improbable Construct » Thu Aug 29, 2013 6:37 pm
ACME Z-axis kits are back in stock.
I received the shipment of rods today and as of... Now! :)
They are available for purchase and immediate shipping.
Shapeoko 3 # 0003
Store:
Twitter:
