ACME screw upgrade for Shapeoko Z-Axis
sell your stuff here
Forum rules
Improbable Construct
Z axis ACME screw upgrade price reduction
Post by Improbable Construct » Thu Oct 17, 2013 11:43 pm
ACME Z axis upgrades now $65.00!
I have reduced the price of the Z axis upgrade from $75.00 to $65.00.
I just got in a new batch of the screws and they are available now.
http://www.shapeoko.com/upgrades
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
jkanzaki
Re: ACME screw upgrade for Shapeoko Z-Axis
Post by jkanzaki » Fri Oct 18, 2013 4:41 am
Good to hear.
Shapeoko 1 - dissassemble
calica
Post by calica » Sat Oct 19, 2013 6:40 am
How compatible is the ACME screw upgrade with the changes in v2?
Post by Improbable Construct » Sat Oct 19, 2013 6:19 pm
I am not sure yet.
I need to get the specs of v2.
Hopefully it will be compatable.
Shapeoko 3 # 0003
Store:
Twitter:
gregdestefano
Post by gregdestefano » Mon Oct 21, 2013 4:37 pm
I just assembled my upgrade with the V2 Motor plates. Seems to fit fine, the main problem comes from clearance with the DW660 and the now reversed carriage. IE I've had to space the DW660 mounts out 1/4 in to clear the top bearing plate, and trim down the bottom bearing plate by about a 1/4 in (to the first unused screw hole) to clear the bottom of the router and vacuum mount. But that is more a function/problem of the reverse Z orientation with older hardware than the ACME Z upgrade itself.
BotDoc
Post by BotDoc » Mon Oct 21, 2013 5:12 pm
I'm in the same boat as gregdestefano. Since I'm going to the V2 unveiling tonight in Chicago, I thought I'd take a look at the V2 z-carriage plate first before I modify the bearing plates. I was thinking about adding spacers on the v-wheel bolts and acme nut to move the carriage further out about a 1/4 of an inch for tool mounting clearance. That requires bolts neither Home Depot nor my local hardware store carries and I wasn't looking forward to ordering a box of 100 from McMaster.
gregdesefano, did you also order improbable contructs's DW660 mounts? If I move the carriage plate out, I was going to notch the corners of the mount to fit over the wheel bolts, but I don't like that idea any more that using spacers to move the carriage away from the makerslide. I was contemplating making my own carriage plate, but I want to look at the V2 carriage first.
ShapeOko #1728. 1000mm dual drive y, 500 mm double x, Acme Z, V2 motor plates, DW 660.
Post by Improbable Construct » Mon Oct 21, 2013 6:24 pm
I need to get my hands on one of the new Z axis setups.
I am sure that some parts are going to have to be redesigned.
Hopefully if will not be too long before I can get the parts worked out.
Shapeoko 3 # 0003
Store:
Twitter:
gregdestefano
Post by gregdestefano » Mon Oct 21, 2013 6:40 pm
I have IC's mounts and I tried notching to clear the bolts, but then the mount wasn't far enough off the carriage plate to clear the bearing blocks. So I had to put a spacer on the DW660 mounts themselves to push them away from the carriage to clear. It works for now and I'll try to cut new "farther away" mounts with notches to go around the wheel bolts after this is all up and running, or if Improbable Construct makes some i'll just buy those =) If anyone want's pics of my V2/ACME DW660 setup I can post them soon, trying to finish wiring it all up today.
Post by Improbable Construct » Mon Oct 21, 2013 8:26 pm
I would love to see some pictures.
I am sure there will be some good solutions to the fitment problems.
Shapeoko 3 # 0003
Store:
Twitter:
BotDoc
Post by BotDoc » Tue Oct 22, 2013 3:12 am
Some photos of the Z carriage from the V2 unveiling tonight.
The Z Carriage is smaller than the V1 carriage. The tool mounts are just below the top wheel bolts and just above the bottom wheel bolts. The Delrin nut is fastened in the middle.
photo 1 by dave847, on Flickr
photo 4 by dave847, on Flickr
photo 3 by dave847, on Flickr
photo 2 by dave847, on Flickr
