ACME screw upgrade for Shapeoko Z-Axis
sell your stuff here
Forum rules
phinsil6
Re: ACME screw upgrade for Shapeoko Z-Axis
Post by phinsil6 » Wed Mar 04, 2015 5:13 pm
sorry to make something so simple complicated, but I have tried opening in inkscape, fusion, autocad and its not opening right in any of them. it opens but the whole thing is scaled by 10. only reason i know this is because i'm able to measure one and only one dimension on the dxf correctly which is the 50mm length.
is there any way you could just provide a drawing with the dimensions or something like that?
Improbable Construct
Post by Improbable Construct » Wed Mar 04, 2015 6:59 pm
phinsil6 wrote:sorry to make something so simple complicated, but I have tried opening in inkscape, fusion, autocad and its not opening right in any of them. it opens but the whole thing is scaled by 10. only reason i know this is because i'm able to measure one and only one dimension on the dxf correctly which is the 50mm length.
Sure, here you go:
PS20101.pdf
(82.48 KiB) Downloaded 311 times
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
mikenmel08
Post by mikenmel08 » Sun Mar 29, 2015 3:50 pm
With the GRBL 0.9g is it still the $2 setting that gets changed when doing this upgrade?
Shapeoko 2 #8233
McOtis
Post by McOtis » Tue Mar 31, 2015 5:30 pm
mikenmel08 wrote:With the GRBL 0.9g is it still the $2 setting that gets changed when doing this upgrade?
Type $$ to display the list of parameters.
Next to each parameter will be a description.
Change the parameter for number of steps per mm for the z axis.
UnequalTech
Post by UnequalTech » Sun Apr 19, 2015 2:43 am
Are these in stock?
Shapeoko 2 #?? w/Makita RT 0701C
Post by WillAdams » Sun Apr 19, 2015 2:53 am
