sell your stuff here
Forum rules
Todd Bailey
Post by Todd Bailey » Thu Oct 04, 2012 12:51 pm
Wow...
This looks great!!!! I read the Wiki and seeing as I am using out of box setup how would I go about changing the controller software for this upgrade?
Thanks... this is on my wish list!
Todd Bailey and ShapeOko - 413
Owner and Creative Designer
4m3D Creative Design
http://www.4m3d.com
Skype Call - todd.4m3d
Phone - 443-450-4633
Newsletter - Subscribe - Free model every issue
loopingz
Post by loopingz » Thu Oct 04, 2012 1:22 pm
Calculate your new steps per millimeter
To calculate steps per inch you need to know:
Steps per revolution of your motors (normally 200 or 400)
Microstepping of your controller: 1, 2, 4, 8, or 16
Thread pitch: The ACME screw is TPI = 12 or pitch = 2.117
So it is: Steps * Microsteps / Pitch = Steps per mm
Ex: 200 * 2 / 2.117 = 188.946623
Finish
Enter your new steps per mm into your control software.
If you are using grbl then $2=188.947 and you are good to go...
Todd Bailey
Post by Todd Bailey » Thu Oct 04, 2012 1:50 pm
Perfect!!!!
http://www.4m3d.com
Post by Improbable Construct » Thu Oct 04, 2012 3:45 pm
Loopingz,
I updated the Wiki page with the grbl settings.
Thanks for the info.
PsyKo
Post by PsyKo » Fri Oct 05, 2012 2:28 pm
Just out of curiosity, what is the kind of lpastic used for the 2 plastic mounts ?
Thanks. It looks like an amzing mod. Probably reduces Z noise a lot.
Shapeoko #736
Post by Improbable Construct » Fri Oct 05, 2012 3:29 pm
PsyKo wrote:Just out of curiosity, what is the kind of lpastic used for the 2 plastic mounts ?
The prototypes were HDPE.
The production version is UHMW.
Both plastics work well and are easy to machine.
CptanPanic
Post by CptanPanic » Tue Oct 09, 2012 12:45 pm
I wonder if you included a second delrin nut so that you can attach to top and bottom of z plate, then this would give a lot more axial support for the z axis. It would also in effect strengthen the z axis plate. What do you think?
Post by Improbable Construct » Tue Oct 09, 2012 3:10 pm
I will give it a try but my guess is that it will be almost impossible to match up the threads.
I guess if one of the nuts had slots in it, it could be adjusted up or down to match the threads and act as a poor mans anti-backlash nut.
I have been running jobs with the ACME mod for a couple of months and haven't had any problems with backlash.
Post by edwardrford » Tue Oct 09, 2012 3:32 pm
Good thinking guys! If one set of holes were slotted (or had some play) you could put a spring between the bottom delrin nut and the top (sloppy) nut, that would give you a "true" anti-backlash solution as they would always be pushing against the threads.
CptanPanic
Post by CptanPanic » Tue Oct 09, 2012 5:16 pm
edwardrford wrote:Good thinking guys! If one set of holes were slotted (or had some play) you could put a spring between the bottom delrin nut and the top (sloppy) nut, that would give you a "true" anti-backlash solution as they would always be pushing against the threads.
Yes, good thinking.
