Forum rules
What material is the screw made of?
Does anyone suffer from backlash in excess of 0.01"? I am deciding if I should use the ACME screw or find a ball screw and nut. It seems like the delrin would need replacing after a certain number of motion hours.
Also, when will the kit be available again?
-Kyle
-Kyle
The current ACME screws are stainless steel.
I have yet to have anybody report a worn out Delrin nut. I only replaced the nut on my machine when I switched to a 4 start screw, but it is still just a delrin nut.
Screws are back in stock.
Any idea when they'll be in stock again? I think it's time for me to make the plunge.
I hope to have them back in stock early next week.
You can check here for updates:
http://www.shapeoko.com/forum/viewtopic.php?f=12&t=3255
If you had to sum up this upgrade to one main benefit, what would it be? My stock Z rod and screw move very nice and seem to be very accurate. Thanks.
On the wiki: http://www.shapeoko.com/wiki/index.php/ACME_Z-axis
there's also the vanity of having upgraded all the axes --- that's why I did it.- 3D carving and speed-constrained on the Z (not as much of an issue if one can change the acceleration limit as on more sophisticated boards)
- Greater Z-axis accuracy (multi-layer PCBs w/ small traces)
- Greater strength and better support
- Being constrained at both ends allows one to spin the rod and move faster w/o whipping
Hi,
May I do this upgrade to a Version 1 Shapeoko? I seem to have damaged my delrin block.
Roo
Roo
There was a version for the SO1: http://www.shapeoko.com/wiki/index.php/ ... _%28SO1%29 but the parts are slightly different from the one for the SO2.
Should be easier to just source a replacement block.
ramos96 wrote:Hi,
Roo
I have a version available in the store for the shapeoko 1. It comes in black or white.
http://shop.shapeoko.com/products/shape ... me-upgrade
IC. I need to contact shapeoko store regarding shipping but I can not find contact us in the site can you give me the contact mail.
Also am still unable to send private messages I just registered. Thanks
Shapeoko 2 full kit # unknown .. Makita compact router .. ACME Z axis upgrade kit
